Hello
using QTPro, the editing arrows on the QT screen below the movie can be finely tuned using the keyboard left arrow and right arrow.
its very slow. is there a modifier key that speeds they keys up?
thanks rotut
Nope, the arrow keys (and mouse scroll wheel) only advance one frame at a time. You'll just have to use the mouse to position the playhead where you want it, or activate the fast-scroll buttons.
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté." -
thanks
unfortunately I do not know what the fast scroll buttons are. if I select one of the editinig arrows on the program, the use the button on the left or the right of the 'paly' button, it palys the movie and does not move the editing button.
are the buttons on the R and the L of the play the fast scroll buttons?
thanks rotut -
Yes, those are the fast scroll buttons. No idea what you mean by it not moving the editing buttons...
hello again
sorry for being imprecise. I was trying to speed up the edit buttons, to faster than a frame at a time.
my mouse skills moving the editting buttons leaves something to be desired, and it seems to take 'forever' to move the editting triangleswith the L/R arrow keys.
maybe there is no way at all to speed this up.
if I select an edit arrow, and then the fast forward or fast reverse, it reverts to the play mode, not the edit mode.
does this help clarity?
thanks rotut -
OK, I think I see what you mean. No, there's no other way but to go one frame at a time, or use the mouse to move the selector. I'd suggest getting a nice Logitech wireless optical mouse for precise mousing.
thanks for all your help
indeed the other day I upgraded my mouse from a wired logitech to the MX 700.
it might help a little, but its hard to get the time pointer close enough. I have a TV card (alchemyTV - great one) and have a lot of cooking shows to edit.
Ill ask a QTPro scripting question in another thread about that!!
Rotut
HHD speed - How important in editing?
By videobread in forum ComputerReplies: 4Last Post: 6th Nov 2011, 15:54 -
How to restore desktop shortcut arrows and folder/file icons.
By lelouch283 in forum ComputerReplies: 1Last Post: 6th Sep 2010, 22:24 -
Need help with Virtualdub deshaker. Arrows all over the finalized video.
By cannondale1974 in forum EditingReplies: 4Last Post: 25th Aug 2010, 23:46 -
Editing an AVI file so I am just left with the VIDEO Avi (No Audio)
By incrediblej in forum EditingReplies: 6Last Post: 26th Mar 2008, 19:16 -
Flashing Arrows To Emphasise
By Squid_uk in forum EditingReplies: 10Last Post: 13th Mar 2008, 22:17
