Hi, I just bought a Pixelview PlayTV Pro Ultra, and when I capture using s-video, I only get black/white. When I capture in composite, colours are OK. Anyone knows why? I managed to get colour on only 2 occasions, but couldn't capture in colour again since then. Is my card faulty? Thanks.
That or you using the wrong video mode let say you be pick PAL but you forgot check the PAL option and end up being NTSC or other way around dbl check your setting.
One other possable is a bad S/Video cable. -
You might want to check your cable. The pins in a standard S-video cable are easy to bend, or miss the connector. Since chroma is carried on a separate set of pins, the general symptom is - no color!
Thanks for replies.
I chose the right options (S-video input), and am also quite sure the cable is OK.
Any other CX23883 users having problems with the s-video input? Thanks. -
Are you using a TBC? Is there any other hardware between your video source and your capture card?
I use a TBC (A DataVideo TBC-1000). If I use the S-Video cables the video is in black and white, but if I use the composite cables the video is in color. This sounds just like your problem, raindance. If I remove the TBC from my capturing setup, the color comes back when using S-Video cables. It appears that the TBC strips out the color on the S-Video output, but I'm not sure.
I called DataVideo and asked about it - the man I talked with did not have an explanation.
only black & white from S-Video
By Victor Hen in forum Newbie / General discussionsReplies: 11Last Post: 23rd Jul 2012, 21:40 -
Connecting with s-video = black/white
By InthaHouse in forum Capturing and VCRReplies: 4Last Post: 10th Aug 2010, 03:13 -
black pixels on white video?
By huttonhenrysfinest in forum Software PlayingReplies: 4Last Post: 23rd Feb 2008, 07:01 -
video capture in black and white only
By oldboy29 in forum Capturing and VCRReplies: 8Last Post: 13th Jan 2008, 18:54 -
HELP, every video on my PC is Black and white ?
By shammi in forum Newbie / General discussionsReplies: 5Last Post: 19th Jul 2007, 08:52
