I have a PAL DV video file. My goal is to make a SVCD compliant video of it using the apple MPEG2 encoder. I did the following procedure
1. Opened th e DV file with QT pro
2. Exported the video using the apple MPEG2 encoder that comes with DVD studio; framerate 2,5 + save audio
3. Converted the audio AIFF file to a MPEG layer 2 audio stream
4. Used TMPGenc to multplex the streams (SVCD template) (VPC)
5. Burned the video using Nero (VPC)
It played ok on my pioneer DV444
But the quality is not too good. When I did another test with a higher framerate, the sound was distorted and the video became choppy.
I want to do another test with the above procedure but I first want to resize my video to the SVCD standard of 480 X 567 before encoding it.
What is the best solution for this and what settings do I need to configure. I prefer a mac tool. Please some help
Does QT pro resizes it or TMPGenc?
I wouldn't resize before encoding but during.
You could always try better CD-r's or a CD-rw.
Just some small tips because of a lack of SVCD experience...
Mark
Video stream size decreasing after deumxing?
By smackyourfupa in forum Video ConversionReplies: 4Last Post: 12th Mar 2011, 04:50 -
Help converting small size but large stream size asf video stream file?
By apple4red in forum Video Streaming DownloadingReplies: 5Last Post: 11th Oct 2010, 11:01 -
Shrink AC3 stream size?
By zmin in forum AudioReplies: 1Last Post: 2nd May 2009, 10:32 -
Clarityof % Size vs % Resize
By solarblast in forum EditingReplies: 19Last Post: 8th Jan 2008, 13:30 -
what is the standard size or need to resize background
By leinan in forum Newbie / General discussionsReplies: 4Last Post: 6th Jun 2007, 13:24
