the description of the file says its a DVD iso image about 5 eps. is it possible to make it into a VCD without burning it to a DVD(since i dont have a dvd burner) only using the ISO image when i extract the rars.
is it worth dling since its such a big file and will it take a long time to change them from dvds to vcd format(mpg)?, im new to extracting from dvds since this is the first time im dling a dvd image. any advice on how to do it(will video quality change?time consuming?programs that i can use)
Mount the DVD iso to a virtual drive using daemon tools. then follow a conversion guide to the <------ left for converting from DVD to VCD.
thanks for the reply, has anyone ever done this before? how long would it take to use Daemon Tools and turn it into a vcd format. i wanna get an idea of how long the process would take before dling the rars and extracting it, since its a huge file.
thanks in advance -
You havent read any conversion guides have you!!!???
daemon tools only loads the image like putting a disc in the drive. you need to read the conversion section for what programs & time frames.
Reading is the key!!! -
Converting a DVD into a VCD can take a long time depending on the software you use, your settings and your computer specs. The sky's the limit if you have a very slow system. Fill in your specs and maybe someone will be able to give you an estimate.
How to Extract an ISO Image without burning to dvd?
By skorpinok in forum ComputerReplies: 8Last Post: 26th Sep 2018, 02:07 -
compare iso image with DVD/CD
By perfection in forum Newbie / General discussionsReplies: 14Last Post: 26th Jun 2011, 12:38 -
create a dvd menu from iso image
By DSLGuy in forum Authoring (DVD)Replies: 3Last Post: 19th May 2008, 09:30 -
Standalone DVD Player to read iso image and VTS files
By bluemoss in forum DVD & Blu-ray PlayersReplies: 6Last Post: 19th Nov 2007, 14:45 -
Can't burn .iso image file onto the DVD+R
By BabaKali in forum Newbie / General discussionsReplies: 12Last Post: 26th Sep 2007, 05:44
