hi there
after several unsuccessful attempts, i managed to get the program working perfectly (much help from previous forum threads).
i converted an Xvid to mpeg-2 using the DVD hi-bitrate preset. the source info is as follows:
VIDEO: mpeg4, 560x240, 23.98 fps. AUDIO: mp3, 44100 Hz, stereo, 107 kb/s
*problem 1: the video is *slightly* jerky, a very subtle difference between the original avi and the authored DVDR, but enough to be noticeable on handheld pans.
would changing the framerate setting from NTSC FILM to NTSC solve this? Or simply complicate matters?
One clue(?): the authored disc doesn't play in Apple's DVDPlayer, but works perfectly in VLC and MPlayer.
Also: I hit 'best' on the bitrate calculator after loading the preset, and the Video Bitrate dropped from 4000 to 2994. Maybe I should leave it alone?
*problem 2: is there any way to have the final 2 channel audio the default track? I don't have surround support.
I love this app! Thank you major.
best,
lokust
i threw out everything like a fool; this is from one of the VOB files on the authored DVDR:
VIDEO: mpeg-2, size: 720x480, 23.976 fps, 2994 kbps. AUDIO: mp2, 48000Hz, 224 kbps.
as for the audio thing, i didn't touch anything on the audio tab after i loaded the hi-bitrate DVD preset
thanks!
Aha. No, I didn't enable this option. Why would the preset forego this?
Any thoughts on the audio? I should mention it registers on VLC (for example) as 'unknown (A52)'...as opposed to 'unknown (mpeg)'. Am I muxing improperly? I have only worked with the resulting video_ts folder when taking a project to toast, so I don't know when I might have gone wrong.
Thanks again for the app (I'm quite aware that "thanks" rings truer with $$!)
MKV newbie - video slightly skips using MPC
By captenblack in forum Newbie / General discussionsReplies: 5Last Post: 25th May 2009, 19:41 -
Digital 8/Hi8 to DVD, slightly choppy.
By Dixie Paul in forum Newbie / General discussionsReplies: 3Last Post: 18th Jan 2009, 16:20 -
Slightly Choppy Youtube Video
By jooleyen in forum Video Streaming DownloadingReplies: 4Last Post: 9th May 2008, 00:54 -
Building A Video-Editing PC (slightly off topic)
By GrayStrickland in forum Media Center PC / MediaCentersReplies: 4Last Post: 26th Feb 2008, 13:39 -
video is slightly wider than the tv screen.
By aruwin in forum EditingReplies: 8Last Post: 21st Jun 2007, 11:57
