I have problems installing the laters XVid codecs 1.0.1 because in the middle of installation the window pops out saying that c:/windows/system32/xvid.ax cannot be deleted, and installation is recommended to be aborted. How do I delete this file. I unstalled the old xvid codec using add/remove programs in control panel, but it did not help.
Foxconn A79A-S|AMD Phenom 9950 BE|8GB RAM|150GB WD Velociraptor|2 HD4850 in Crossfire|Windows Vista 64 Ultimate SP1
Abit NF7-S|AMD Barton 2500|1GB RAM|3*160GB HD|HD3850|Windows XP Pro SP3 -
If what BJ_M said does not work, just boot windows into Safe Mode and delete the file from there. The xvid.ax should not be in use in Safe Mode.
If you've got a old OS like Win98/ME, then boot in dos and delete the file from there.
To get into Safe Mode, hit F8 on boot up. You must hit F8 before you see the Windows loading logo.
............deleted
By elistian in forum DVB / IPTVReplies: 7Last Post: 20th Jul 2009, 00:48 -
Need to recover deleted files
By alegator in forum ComputerReplies: 5Last Post: 16th Apr 2008, 22:38 -
deleted....
By mjwhite in forum Latest Video NewsReplies: 1Last Post: 31st Dec 2007, 14:19
