DVDFab has been giving me problems on my Sony players. I'm looking for some kind of way to fix the DVDFab output files.
i've had problems with getting pause, fast forward, rewind, and slow motion forwards and back to work properly for the 2nd disc from a split dvd.
the player just jumps back to the start of the chapter when pressing play after using fast forward, rewind, or pause. slow motion makes the player jump back to the start of the chapter.
this happens on my 2 Sony players:
-Sony DVP-S525D
-Sony DVP-NS730P
i'm dealing with PAL discs. this has happened on most of the discs i've done. only one disc works properly out of the 5 i've done. some discs work properly for the last few chapters of the disc, but the first few chapters don't work properly.
these same discs play properly in pioneer players and in windvd and powerdvd.
discs made with other software play perfectly.
my burner is a pioneer DVR106P. all versions of dvdfab i've tried do it. i've tried from 1.7 up. i run windows 2000. i rip with my burner. the burning software i use does not make any difference. i use tdk dvd-r discs (2x and 4x) and tdk dvd-rw discs (2x).
is there any way to fix this problem? there are many people out there using sony players. what i'm really looking for is some kind of software fix, like repairing the output files of DVDFab by using another program.
