Greetings to all.
I have a Sparkle GeForce FX5200 and, when I connect it to my TV, the TVscreen flicks for less than 1 second. This repeats 30 in 30 seconds. It's very annoying. I have installed the latest NVIDIA drivers and also a software called TVTool8. But the problem remains. Could it be a deffective VGAcard?
TIA for any help.
connect it with your computer off then bootup. Then go in and make sure you enable the TV as one of your displays under the display properties. Personally, I do not feel you need to use TVtool if you have recent NVidia drivers as they have added sugificant TV support within the last few revs. I use NTSC, it could be different for PAL though.
-Suntan
nVidia fx5200 new drivers
By maansingh169 in forum Media Center PC / MediaCentersReplies: 1Last Post: 20th Aug 2008, 22:16
