Well, I read the documentation but I apparently didn't get it. I set up my Root menu to loop (dragged its out point back to its beginning), and set up my buttons to automatically select after a certain amount of time which corresponded to three loops of the menu. Apparently, that wasn't what was needed, because the menu played once and then went directly to the first movie.
Anyone know what I should be doing to accomplish, say, three repeats of the menu, then leading to the first movie automatically?
Gonna have to re-encode the movie again and set up a lot of I-frames this time around, because all my chapter stops were way off. Even though I'm positive most of them _were_ on I-frames. (Well, dramatic scene changes, at the least. :P )
The loop is a post VM command in the menu. When you set a default button to be executed, and it times out and executed, the post VM commands are never executed. When a button is pushed flow is to the linked object. You never return to the calling menu to execute POST VM commands.
DLP VM Commands will do it:
Increment a GPMR as a VM post command with each loop and check it as a pre VM command.
hints
Pre VM
GPMR1 = 3
if (GPMR0 == GPMR1) jump ......
Post VM
GPMR0 +=1-----------------------------------------------------
There is a reason why God gave us one mouth and two ears!!! -
Okay, well. I put the code in. Far as I can tell, each time the menu loops, I have a variable set up to increase by one, and should said variable ever reach the value of 3, then the next time the menu tries to play, it will skip directly to tt 1.
Load the result into WinDVD and it just loops the menu forever.
So, like, what the heck?
My syntax:
PreVM:
GPRM1=0x3
if (GPRM0 == GPRM1) JumpTT 1
PostVM:
GPRM0 +=0x1
The only possible issue may be that I cannot tell which "TT" my non-menu movies are. If DVD-Lab presents that information, it sure seems to hide it well. -
If you've set a force activate button, then what happened is correct because this is a vob instruction which will override the loop. The time you've set is the still time after the cell has done playing. It won't make it loop.Originally Posted by Colmino
The syntax awlchu gave you is OK. It may be that when doing the loop DVD-Lab resets GPRM0 or links to another PGC first where it modifies its value or something silly like that. In this case do the loop yourself. Add a post command LinkPGCN X, where X is the PGC number of the menu (you have to find this; it may not be 1 even if it's the first menu because I think DVD-Lab puts some default PGCs on its own before your menus).
It may also be that before the pre command section is executed, GPRM0 is not 0 because its value has been modified in another PGC. In this case put as a first pre command If (GPRM1!=3) GPRM0=0. This will assign 0 to GPRM0 but only if GPRM1 is not 3.
Also before the jumpTT command you'll need to reset GPRM0 to 0 (or GPRM1 to 0 if you've added the upper command) otherwise you won't be able to call the menu anymore (as soon as you get to the pre command section it will jump back to the title because GPRM0 is 3).
Another thing. What kind of menus are they, VMG or VTS? If they are VMG, fine but if they are VTS menus, jumpTT is not a legal command there, so, depending on the player, it may ignore it and loop forever. You need to replace it with jumpVTS_TT.
DVD Lab Pro 2's Render Menu Motion - Intro and Loop Questions?
By xhonzi in forum Authoring (DVD)Replies: 3Last Post: 21st Sep 2009, 18:52 -
dvdauthor, GfD - Animated menus hesitate at end of loop
By jsbullock in forum Authoring (DVD)Replies: 2Last Post: 29th Jun 2009, 02:55 -
Cell Menus Dvd lab pro
By angelus214 in forum Authoring (DVD)Replies: 2Last Post: 8th Oct 2008, 10:52 -
loop entire video in dvd lab pro?
By sarcastik in forum Newbie / General discussionsReplies: 1Last Post: 18th Nov 2007, 20:04 -
Should the audio and video times match in DvD Lab?
By janeydoll in forum Authoring (DVD)Replies: 14Last Post: 9th Jun 2007, 14:45
