i'm trying to convert avi to dvd..
i use Tmpgenc express 3.0 so i can put a few movies to encode..
all the mpg is playable on PC smoothly
then i tried to author it.. using tmpgenc author
and after that burned..using
tmpgenc
imgtool/dvd decrypter
Nero
all method give me jerky and stuttering movie when played on panasonic DVD stand alone.. but my other DVD & powerDVD able to play it smooth
i also try DVD-lab for authoring..same result..(slightly better though)
have tried many DVD..(prodisc,ritek,memorx)... and still couldn't figure out whats wrong..
anyone please help me...
do i need to reencode from scratch..??
not sure if this the field problem..since some of episodes..works fine and some of not (they are encode the same way)...
