hello,
this is my first post in this forum
I just want to know how can I put a long text that can be scrolled in a menu page... what program is able to do that?
thanks
You can create a series of menus with text on them. Then you can put a NEXT and a BACK button on the bottom to link to each menu.
Most DVD Authoring apps should be able to do this. DVD-Lab will do up to 99 menus.Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
thanks for your help, but I´d like to put a long text in just a menu page... so I need a scrolling text on it
In that case, you'll have to make a video of the scrolling text then import it as a motion menu. Any good video editor should be able to do that.
in fact my idea is having an up and down arrow button to control the scrolling text
I don´t know if creating that video with the scrolling text the button thing can be done... and, I want to do that in several menu pages, so creating a video for each one can be a long work -
That would be imposible due to DVD specs. The best you can do would be to hit the pause button to pause the text.in fact my idea is having an up and down arrow button to control the scrolling textGot my retirement plans all set. Looks like I only have to work another 5 years after I die........
What about using the switched menus concept with a motion menu?
You might want to try this. I'll assume that you have 3 lines of text that you want to scroll.
1) Create 3 motion menus, one for each of the sets of scrolling text.
2) Use the DVD-Lab Switched menu function. See the MediaChance website for a tutorial on switched menus if you are not familiar.
3) Link one would be scrolling text 1, when you pressed down, menu 2 with scrolling text 2 would load and run, repeat with the third menu.
Blurred Text on DVD Menu
By boofer in forum Authoring (DVD)Replies: 3Last Post: 10th Jan 2009, 18:45 -
extract dvd menu text & time
By msdiane in forum Newbie / General discussionsReplies: 0Last Post: 26th Oct 2008, 12:25 -
editing text in menu in an already made dvd
By gameroftheuk in forum Newbie / General discussionsReplies: 2Last Post: 18th Aug 2008, 22:32 -
DVD Lab - menu text blurred (PAL)
By BeachNut in forum Authoring (DVD)Replies: 12Last Post: 21st Jan 2008, 07:12 -
How to create DVD menu buttons in Photoshop w/text only highlighting?
By rbatty11 in forum Authoring (DVD)Replies: 5Last Post: 30th Nov 2007, 20:58
