Results 1 to 11 of 11
    Sep 2001
    fondoo
    can anyone recommend me a prgm that rips faster than dvdx?
    i'm interested in DVD to MPEG format. thanks in advance.
  2. why dont u ripp it with DVD Decrypter first thats way faster
  3. DVD Decryptor -> HD
    Vobs->DVD2AVI->Mpeg2Dec+Avisynth->CCE
    Guides for all that at doom9.org
    Sep 2001
    fondoo
    where can i find this DVD Decryptor??
    Sep 2001
    fondoo
    can anyone tell me how to use mpeg2dec?
    i ran dvd decryptor ->HD
    VOBs->DVD2AVI
    now i'm up to the point of mpeg2dec and i dont know how to use this program. i now 2 files (.wav and .d2v) created by DVD2AVI.
  6. You have to write a Avisynth script to use MPEG2DEC. Go to Doom9's site he as a guide to using AvisynthMMX and MPEG2DEC.
  7. Welcome to the AVISynth cult, it's the fastest way to rip
    Sep 2001
    fondoo
    can someone give me a hand? i was following the instructions on how to write a script for DVD2AVI-MPEG2DEC at http://www.doom9.org/mpg/d2a-mpeg2dec.htm
    i was able to create a notepad file and named it test.avs and it worked. but i got stumbled at this part:
    To load the MPEG2Dec plugin you have to use the LoadPlugin command and give it the full path and filename of the plugin to load as argument. The next step is loading your DVD2AVI project file using the mpeg2source command. Note that MPEG2Dec provides this function so if you forget LoadPlugin it won't work. The following is a sample scrip which simply opens the d2v file.
    LoadPlugin("c:\temp\MPEG2DEC.DLL&quot
    mpeg2source("D:\matrix\matrix.d2v&quot
    where can i find this load plugin command?
    Feb 2001
    Berlin, Germany
    The command is
    LoadPlugin("c:\temp\MPEG2DEC.DLL")
    That requires, that you extracted mpeg2dec.zip to c:\temp directory. Otherwise type the correct path to mpeg2dec.dll.
