  1. 14 June
    I am trying to convert some movie -VIDEO_TS 7.35 GB using ffmpegX 0.0.9k to SVCD.
    After following intructions and after 7 hours I got:
    -movie.mpg.avi.sub 10.2 MB
    -movie.mpg.avi.idx 96 kb
    -movie.mpg.avi 2.4
    -movie4.avi 3.27 GB. I played this one using VLC and it was OK,
    Quicktime couldn’t handle it.
    I was supposed to have something that will fit on 2 cds? How?
    Now what must I do to burn it using Toast Titanium?
    Framerate -PAL(25) is OK?
    What am I missing?
    eMac IGB, OS 10.3.4, 512 ram
    Progress window:
    Encoding started on Mon Jun 14 16:32:09 CDT 2004
    Using GNU internationalization
    Original domain: messages
    Original dirname: /sw/share/locale
    Current domain: mplayer
    Current dirname: /usr/local/share/locale
    MEncoder dev-CVS-030226-15:00-3.1 (C) 2000-2003 Arpad Gereoffy (see DOCS)
    AltiVec found
    Reading /Users/fraterma/.mplayer/codecs.conf: Reading /usr/local/etc/mplayer/codecs.conf: Using built-in default codecs.conf
    Reading config file /Users/fraterma/.mplayer/mencoderReading disc structure, please wait...
    There are 2 titles on this DVD.
    There are 12 chapters in this DVD title.
    There are 1 angles in this DVD title.
    File not found: 'frameno.avi'
    libdvdread: Couldn't find device name.
    DVD successfully opened.
    success: format: 0 data: 0x0 - 0x24D6C800
    MPEG-PS file format detected.
    VIDEO: MPEG2 720x576 (aspect 2) 25.00 fps 6250.0 kbps (781.2 kbyte/s)
    [V] filefmt:2 fourcc:0x10000002 size:720x576 fps:25.00 ftime:=0.0400
    Opening audio decoder: [liba52] AC3 decoding with liba52
    Using AltiVec optimized IMDCT transform
    AC3: 2.0 (stereo) 48000 Hz 192.0 kbit/s
    AUDIO: 48000 Hz, 2 ch, 16 bit (0x20), ratio: 24000->192000 (192.0 kbit)
    Selected audio codec: [a52] afm:liba52 (AC3-liba52)
    Opening video filter: [expand=-1:-1:-1:-1:1]
    Expand: -1 x -1, -1 ; -1 (-1=autodetect) osd: 1
    Opening video filter: [scale=928:704]
    Opening video filter: [crop=668:566:26:2]
    Crop: 668 x 566, 26 ; 2
    No accelerated resampler found
    The selected video_out device is incompatible with this codec.
    Opening video decoder: [mpegpes] MPEG 1/2 Video passthrough
    VDec: vo config request - 720 x 576 (preferred csp: Mpeg PES)
    Could not find matching colorspace - retrying with -vop scale...
    Opening video filter: [scale]
    VDecoder init failed
    Opening video decoder: [libmpeg2] MPEG 1/2 Video decoder v2.0
    libmpeg2: No accelerated IDCT transform found
    libmpeg2: No accelerated motion compensation found
    VDec: vo config request - 720 x 576 (preferred csp: Planar YV12)
    VDec: using Planar YV12 as output csp (no 0)
    Movie-Aspect is 1.33:1 - prescaling to correct movie aspect.
    SwScaler: reducing / aligning filtersize 2 -> 2
    SwScaler: FAST_BILINEAR scaler, from Planar YV12 to Planar YV12 using C
    videocodec: libavcodec (928x704 fourcc=58564944 [XVID])
    Selected video codec: [mpeg12] vfm:libmpeg2 (MPEG 1 or 2 (libmpeg2))
    audiocodec: framecopy (format=2000 chans=2 rate=48000 bits=16 bps=24000 sample=1)
    Writing AVI header...
    New_Face failed. Maybe the font path is wrong.
    Please supply the text font file (~/.mplayer/subfont.ttf).
    subtitle font: load_sub_face failed.
    Skipping frame!
    Skipping frame!
    spudec: Error determining control type 0x41. Skipping -6 bytes.
    spudec: Error determining control type 0x71. Skipping -6 bytes.
    Writing AVI index...
    Fixing AVI header...
    Video stream: 3745.531 kbit/s (468191 bps) size: -955583314 bytes 7132.520 secs 178316 frames
    Audio stream: 192.000 kbit/s (24000 bps) size: 171183360 bytes 7132.640 secs
    Encoding completed on Mon Jun 14 23:11:02 CDT 2004
  2. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    You say you are converting DVD to SVCD, but your output is .avi. SVCD output should be mpeg (.mpg), optionally followed by disk images (.img).
    Did you use a preset? (Good idea)
    Did you change the video codec? (Should stay on mpeg-2)
