Yeah ill take a avi file that is only 600mb and after i convert to vcd its 1.6 gig can someone help.........need to know if there is a way to compress!
Sure,
You can compress it to DivX !! The file will probably be around 600Mb..... just kidding.
You probably want it converted to VCD in order to play it on a VCD/DVD player, right ?
Well, there's no way of compressing a VCD to anything smaller than it is and still keep it VCD compliant. What you CAN do though (but isn't really recommended) is make a XVCD and instead of raising the quality, lowering it. You can do this by changing the audio bitrate to something lower (96kbps or 112 kbps) also Joint Stereo instead of Stereo should help a bit. The most compression is gained by lowering the bitrate of the movie itself. But this also causes great quality loss !!
One thing i can tell you for sure : You'll never get the whole thing on 1 disc and still be able to propperly view it.
My advise to you : Cut the file in half so you have 2 files of 800 (or less) MB. Just burn them as VCD's and you're done. If the files are over 800Mb, try losing the end credits..
Hope this helps.
Greetz,
pSYcHo DaD
_________________
The difference between genius and insanity is only measured by success !
<font size=-1>[ This Message was edited by: Psycho_Dad_Rules on 2001-07-13 05:10:26 ]</font>
<font size=-1>[ This Message was edited by: Psycho_Dad_Rules on 2001-07-18 04:58:03 ]</font> -
Thanks man it helped!..............i think im going to give it up though on vcd's quality sux when i do it blocks neon colors looks horrible! i dont get it i download vcd's from people that they already converted and burn them and the quality is almost as good as a dvd--there perfect and mine look like a childs coloring book!lol
Converting from a DivX to (S)VCD is never a good idea, unless the DivX is of really good quality. Since DivX is already compressed there is some quality loss there already. By re-encoding to VCD, which causes even more quality loss, you can only make things worse.
The best thing to do would be to get your hands on the original DVD and rip from that.
Increasing the bitrate can/will create better quality VCD's but will also increase your filesize,
Greetz,
pSyChO dAd
Need help with compression
By dfreeman1971 in forum Authoring (DVD)Replies: 7Last Post: 4th Jun 2010, 01:18 -
Better Compression?
By anirban in forum Video ConversionReplies: 20Last Post: 5th Oct 2008, 17:19 -
Compression
By darts44 in forum Newbie / General discussionsReplies: 7Last Post: 10th Nov 2007, 22:51 -
more compression?
By jwfc in forum Newbie / General discussionsReplies: 2Last Post: 10th Jul 2007, 14:22 -
compression
By m-man in forum Newbie / General discussionsReplies: 5Last Post: 4th Jul 2007, 12:18
