johnnybgood, you are most welcomed!
pabcsn, they should be available on this forum in the OTHER / TOOLS section
Førby, I think the problem is that you used Xing, all the encoding i've done are with TMPGEnc
themods, CQ_VBR = Constant Quality with Variable Bitrate.
biggs, since SxVCD is burned as a SuperVCD you may need to do the same change as you would on a regular SuperVCD (burn in the MPEGAV instead of MPEG2 location)
Results 1 to 1 of 1
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
Template for effect.
By tomofthefuture in forum Newbie / General discussionsReplies: 1Last Post: 21st Apr 2011, 17:04 -
A simple, easy to use website template?
By sdsumike619 in forum ComputerReplies: 2Last Post: 23rd Apr 2008, 06:02 -
Printing Template
By mleb33 in forum Newbie / General discussionsReplies: 0Last Post: 29th Sep 2007, 09:09 -
Sefy's Guide and Correct Setting for DVD (NTSC).mcf
By moviebuff2 in forum Newbie / General discussionsReplies: 8Last Post: 1st Aug 2007, 10:01 -
Template selection in CCE...
By hiimbored in forum DVD RippingReplies: 5Last Post: 28th May 2007, 19:54
