What I want to know is this....
Can you convert a VHS tape to an MPEG2 file (on the HD) on a set-top DVD-Recorder and then take that MPEG2 file and put in on your computer and author and burn it yourself?
I just want to know because I want to create files that are already VBR encoded (so I know they fit on DVD) but I don't want to have to use the set-top DVD-Recorder's authoring/menus/chapters...
Yes.
I own a Philips recorder. I record with (+)RW discs then add chapter markers and better looking menus with either TMPGEnc DVD Author or Ulead Movie Factory 2.0 depending on my mood that day..
As far as REAL editing goes....your better off doing that in the recorder. Much easier that way. You can do that by dividing the title or adding chapter markers in the DVD Recorder(in a Philips recorder anyway).
Most DVD Recorders WILL NOT record factory made VHS tapes(like movies and concert video) due to the built in copy protection on the tapes.
You will need to circumvent that. -
Oh ok, I see, you take the video off of the DVD-RW and put it on ur PC...then create your own menus...
Thanks for the info!:) -
Have a look in the DVD Recorder forum... lots of great info:
https://www.videohelp.com/forum/viewforum.php?f=28
Best software to edit and burn mpeg video on PC?
By daysaf00 in forum Authoring (DVD)Replies: 3Last Post: 29th Jan 2012, 02:02 -
Edit and Burn DVD from Canon DC230 video camera
By atlanta_joe in forum Newbie / General discussionsReplies: 3Last Post: 31st Dec 2008, 16:41 -
Question on new Panasonic dvd recorders
By heman28 in forum DVD & Blu-ray RecordersReplies: 8Last Post: 20th Feb 2008, 11:37 -
Basic question about HD DVD Recorders...
By aim15011 in forum DVD & Blu-ray RecordersReplies: 5Last Post: 19th Dec 2007, 11:08 -
Unable to burn with multiple DVD recorders with Nero 7.9.6.0
By Burner127 in forum Authoring (DVD)Replies: 1Last Post: 6th Jun 2007, 23:47
