Here's the problem. I've tried to install this codec many times with no success. The problem is that the installer finishes as it would normally do, but the codec doesn't show up on ANY programme...Not even in GSpot as an installed codec... so, how can I install it so it works properly???
Results 1 to 11 of 11
Is there any special reason you need to use the canopus codec? I find the Panasonic DV codek to give a more comfortable picture, and it works
Yes. The Panasonic DV codec only supports RGB, and the Canopus one supports both RGB and YUV2.
But if the panasonic DV codec can be used with AviSynth, I'd use that one. Do you know if AviSynth can work with the panasonic one??
Thanks for your reply.
yes
Thanks BJ_M
. I'll see if I can install the Canopus, and if it doesn't work, I'll use the Panasonic codec.
One final question; When I installed the canopus codec before, it didn't show up on GSpot, but if I opened a DV file and clicked render, it would render succesfully, but on the information of the used codecs, an 'unknown codec' was used (the canopus, I guess). So, does the canopus show up as an installed codec in some programme, or it simply doesn't show up? -
simply doesnt show up - same with the main concept ... depends on the program i guess ...
it really only maters which dv codec you are using for RE-encoding ... for playback it doesnt mater"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Hey BJ_M, just one more question...
I read in other thread that you suggested using canon's codec...Is it better than the panasonic one? Which colourspaces does it support? And, finally, does it suffer from the chroma bug (like the canopus codec)?
Thanks for your help.
you can not install it ... its hardware based ..
Yep... you're right
I thought there was a DEcoder from canon, but I didn't find it in a Canon camcorder's CD so... well, thanks again for your help
Try changing the FourCC code of your avi file to "cdvc". That will set it so that dv-avi file will be decoded using the Canopus codec. The default FourCC code dv-avi files uses the M$ codec so installing the decoder for the Canopus codec is not enough. There is a FourCC changer that is supplied with Koepi's build of Xvid although I forget the name of it. The Canopus codec does suffer from the chroma bug so you will have to use FixBrokenChromaUpsampling or ReInterpolate411.
Do you remember when TMPGEnc needed an English patch?
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 15:10 -
Canopus ADVC-100 vs Canopus ADVC-110
By tarrickb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 16th Oct 2010, 21:52 -
MPG File with ivivideo Codec-bad picture.Can I change the codec?
By cska133 in forum Software PlayingReplies: 13Last Post: 4th Nov 2008, 10:41 -
How to use Canopus VideoFx with Canopus let's edit2
By perfection in forum EditingReplies: 1Last Post: 25th Sep 2007, 04:56 -
Should I install Canopus Codec?
By tranbuimd in forum Video ConversionReplies: 4Last Post: 26th Jun 2007, 19:01
Thank you again. That clears things up
