i am using telus ADSL
i have a SMC Barricade7004 Router
and today my connection was fine earlier.. but my other computer's internet connection suddenly stopped working.. like i can't go to websites and stuff.... i did not change anything at all it just suddenly stopped it worked fine before... just wondering how i can fix this problem plz help ASAP
everything is plugged correctly just like it use to be but i donno why it suddenly stopped working
Results 1 to 11 of 11
I recall all the problems you had setting up your router.....Can you get to the router setup page from the browser of the non-working computer? Remember, it should be 192.168.0.1 (or something very similar). If you can get to the router screen, but not out to the internet, you may need to drop and renew your DHCP.
the computer that is not working cannot connect to the router set up page that's the weird thing.... i already tried release renew and everything...
both computer is connected to router but that one cant go to the router page at all ??????????? -
Can you go to a command prompt and ping the router? Sounds like a network card or cable on the non-working computer.
You can test the card with a loopback ping. Ping 127.0.0.1 If theres no response there, it's either the card or the config.
You can try power-cycling the router.
I had the same model and really loved it, now I only buy SMC routers. -
Possibly, but I would think that if it were the router, the other pc would not work as well.....Originally Posted by mujahid7ia
Or possibly one defective LAn port (very far-fetched, i know). You can try changing the port.
EDIT: I re-read your first post, if it suddenly stopped working, then you should power cycle both modem and router. Also, is DHCP enabled in the router? In your network settings on the affected PC, is it set to automatically get the IP address or is it manual? -
I would still like to know if he can ping the local machine. That would rule out the router right there. While a power cycle on the router and modem is a valid first step in troubleshooting, if the second machine is working, you can rule out the modem since the router sees the connection.
From there, it can only be the router back to the pc(s). One pc working, (probably) not the router, although, yes, could be one LAN port. Does the router show a link with the non-working pc? Check the link lights. Since he can't ping the router from the pc, it is either setup, NIC, or cable. Ping the local machine. Get a response - try a different CAT5 cable, and/or a different LAN port. No response, check the setup, or replace the NIC. -
Does pc 2 connect straight to the router or through pc 1 ?
secured internet connection
By abdosagor in forum ComputerReplies: 24Last Post: 11th Apr 2012, 10:03 -
Why do I keep losing my internet connection?
By Captain Satellite in forum ComputerReplies: 20Last Post: 24th Aug 2010, 20:36 -
Internet Connection Dropping Out
By Sakuya in forum ComputerReplies: 4Last Post: 28th Feb 2009, 00:12 -
Internet Connection Issues
By bluemoss in forum ComputerReplies: 12Last Post: 10th Nov 2007, 12:09 -
Problem with internet connection
By Wizard23 in forum ComputerReplies: 5Last Post: 11th Sep 2007, 11:18
