  1. What is the best tool (software) to convert WMA files to MP3 format. Preferably something fast and that will rip with VERY good quality.
    Your input would be appreciated.
    Thanks tons.
    Jenny
  2. Member racer-x's Avatar
    Mar 2003
    3rd Rock from the Sun
    Try Goldwave.
  3. try cool edited, not free but it worth of purcheasing it, because you can rip from dvd, vcd, cd and convert it to any music media you want.
  4. i use Advanced WMA workshop,by litexmedia.
    it converts to OGG,WMA,MP3,etc,and also converts back from these into any format you choose,in seconds,takes about 30 seconds for an average music album.
    and you can choose the rate you convert to,up to 128 all the way up to 192 and beyond.
    Jul 2003
    michigan
    jetaudio or dbpoweramp, both free
    member since 1843
