Hi everyone
I made a video in combustion with 1094x576 pixel resolution .
My question is the following :
Is there anyway to mantain that video resolution in a dvd?
If there is can anyone explain me how?
Even if i decide to loose 70 pixels of the width to make it into a 1024x576 video- 16:9 DVD - the MPEG-2 will be always compressed to 720x576 - so basically i can never see (at least in a computer) the movie in itīs original size ...
Any suggestions?![]()
thanks a lot
Pedro
Portugal
PS: Portugal uses PAL not NTSC
As you have already pointed out in your own post, PAL resolution is 720 x 576, so if you want to put it on DVD as a compliant video stream for playback, sacrifices will have to be made. You could put a copy of it as an avi file at it's original resolution in the data area of the disk for playback on PCs only. This way you have the best of both worlds.
which resolution for 32" widescreen?
By iancur in forum Video ConversionReplies: 1Last Post: 2nd Feb 2011, 13:48 -
42 inch plasma widescreen (16x9 hdtv has native resolution 1024 x 768 (4x3)
By sbt5 in forum DVB / IPTVReplies: 15Last Post: 4th Aug 2009, 21:59 -
vertical resolution of anamorphic widescreen?
By Sean_ve99 in forum Video ConversionReplies: 12Last Post: 7th Jan 2009, 11:41 -
PLASMA resolution..1024x1080 (or 1024x768) ..surely isnt widescreen?
By snadge in forum DVB / IPTVReplies: 6Last Post: 2nd Sep 2007, 11:24 -
My widescreen slashes resolution
By seragx99 in forum Video ConversionReplies: 1Last Post: 5th Jul 2007, 02:38
