Nvidia 6800
ATI x800
3dlabs VP990 and the VP880
Any others? Thanks guys.
-Jesse
I'm going with the 6800. It and the X800 are very close on marks with the latter getting the edge in AA. I'd venture to say the X800 is better for gaming but the 6800 would make a better combo card for gaming and workstation apps because of its engine and drivers. I would not get anything other than an ATi, nVidia, or Matrox video card unless you're getting a Wildcat or Fire card for a workstation.
If you ask me nvidia are shite, ati all the way, go for the x800
The 6800 is a great card with two exceptions.
1. Needs a 430W power supply. ( Has two molex connectors)
2. Needs two slots ( the fan intrudes on the second slot)
Other than that it is an awsome card."The name on the front of your shirt is more important than the name on the back"
Kurt Russell - Miracle -
Most high end graphics cards take up two slots (the agp and one pci) my 9800 does.
THG said the 6800 required a 480w power supply and two power cables from different rails but actually consumed less power than the X800 which only requires a 430w and one power cable. I wonder why they don't make them with the extra finger for AGP Pro so that they can get a little more juice from the motherboard?
I don't like how they take up a PCI slot though. I only have 4 as it is. At least with this new board the one adjacent to the AGP slot isn't one of my PCI-X slots like it was with the 2460. Still most newer video cards say they only take up one slot but try to fit a PCI card in next to the HSF on most. Also consider that if you do get one in there how much room is there for the GPU HSF to work properly.
Using an Onboard video card with a PCI video card
By Nastydave in forum Media Center PC / MediaCentersReplies: 3Last Post: 6th Apr 2012, 03:37 -
Video files for an Archos AV 500
By merryperson69 in forum Newbie / General discussionsReplies: 1Last Post: 31st Dec 2009, 07:08 -
Looking for new driver for video card- MEDION (7134) WDM Video Capture card
By 2prfm.com in forum Capturing and VCRReplies: 3Last Post: 15th Sep 2008, 03:48 -
Video Capture with Wintv PVR 500
By radink in forum Capturing and VCRReplies: 3Last Post: 11th Aug 2007, 15:05 -
Converting a 72 min NTSC DVD to video file under 500 MB (URGENT!)
By Salva Veritate in forum Video ConversionReplies: 14Last Post: 6th Jun 2007, 15:21
