I'm backing up a long movie and putting it onto two DVD-R. I'd like to have a screen come up saying "Intermission" at the end of the first disc.
Can anyone tell me how I can create the MPEG out of a JPG? I've used TMPGENC, but the resulting MPG file only lasts about a second.
I'm not sure if this is an authoring problem, or something I need to change when I create the MPEG.
I'm planning on using either TMPG DVD Author to add the "intermission" clip or just DVD Shrink.
Thanks in advance.
VCDEasy will make a compliant mpeg out of any jpg/bmp.
Cheers, Jim
My DVDLab Guides -
You can use Windows Movie Maker 2 to generate the AVI file.
Create a BMP file that has required text. Drop that in Windows Movie Maker and assign a length, say 30 secs, or 1 min. Create an AVI file.
Use TMPGENC to encode it to Mpeg2 file. -
Create your bmp or jpg in your favorite program (MS Paint will even work).
Get a piece of audio the required length, or create blank audio of the appropriate length. Windows Sound Recorder can do this if you mute the input (mic).
In TMPGEnc, use your bmp/jpg for the video source and your sound file for the audio source. Select the standard DVD template for your region (NTSC/PAL). It will output 2 elementary streams (m2v, mp2) of the proper length, which you can use in TDA.
How to open movie .PART?
By richadyanato in forum Newbie / General discussionsReplies: 4Last Post: 21st Apr 2012, 11:56 -
how can i edit a small part inside a movie and make that part look bigger?
By xxquatroxx in forum EditingReplies: 1Last Post: 24th May 2010, 15:32 -
Burned a 2prt avi to dvd Loss of audio on 2nd part of the movie.
By Ryanmhindman in forum AudioReplies: 2Last Post: 22nd Sep 2009, 14:43 -
How to apply a filter to just a part of the movie with VirtualDub
By Drakul in forum EditingReplies: 5Last Post: 19th Sep 2008, 17:08 -
Vegas Movie Studio 7/8 will not open the audio part of mp4/mp3
By budwzr in forum Authoring (DVD)Replies: 3Last Post: 17th Nov 2007, 10:47
