Hi. Just wondering if anyone could shed any light on this. I'm converting for example a .avi to Mpeg2 which I use one of TMPGenc 2.5 or 3.0 I then use TMPGenc DVD Author and then NERO to burn.
Occassionally I get a burned file that jumps frames. The player will keep counting but the film pauses, then the counter jumps back a few seconds and the film continues with a jump.
Any one know a few likely causes of this and what can be done to prevent.
Thanks.
Could be many things, but often its bad media. Your player might be sensitive for the media you are using. Did you try to verify the disks to ensure they are correctly burned? You must lower the burn speed if the disks fail to verify, and buy another brand next time. Always spend some time at htt://www.videohelp.com/dvdmedia before buying blank DVDs, will save you both money and trouble.
help jumping from SD to HD
By blacktooth in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 4th Feb 2012, 02:46 -
Virtualdub VCR capture no dropped frames but 5400 inserted frames in 1 hour
By suloku in forum Capturing and VCRReplies: 12Last Post: 17th Aug 2011, 23:33 -
jumping video
By natty in forum Newbie / General discussionsReplies: 8Last Post: 2nd May 2011, 12:27 -
Jumping over movie
By gbabione in forum DVD RippingReplies: 3Last Post: 11th Apr 2010, 05:54 -
8mm Jumping Frames
By DavidA in forum RestorationReplies: 12Last Post: 2nd Sep 2008, 07:01
