I remember back in the day when you wanted a shared directory password protected it was just part of the sharing menu. Now with XP I know that you have to set a user in the Users and Groups in the system tools, but how do I set permissions so that when a user connects to the host computer it asks them for their username/password before heading to the root directory listed in the user's properties? I want to share out my website files so that I can make changes to them from any of the computers in my house so that they all stay unified. I also wanted to map a drive on my laptop for that same shared directory.
OK working from memory here - so take it with a grain of salt!
As long as the host requires users to use a password, persons connecting remotely will have to as well, but usually you take care of this in the netuse statement that connects - or if the remote user is a "user" on the host computer, using the same password, they will get automatic access.
The netuse statement will also log the required directory as a drive for the remote user.
IE
net use v: \\192.168.0.4\C:\hold /persistent:no
will connect the remote user (whom is a registered user on the host, using the same password on the remote computer) to the host 192.168.0.4, seeing the Host C:\hold as V:
If they are not a registered user on the Host, they will be prompted for login and password -
TMI
I have the user added on the host computer in the system tools and that user is part of the Users group. I have set a password and a local directory for it on the host computer which is where the shares are located. Now do I simply share that folder on the network just like any other non-protected share or do I have to map something directly to it from the client computer? -
In Tool>Folder Options do you have Simple Filesharing enabled or disabled?
No, figured that out last night. Opened up a whole ton of options in the sharing menu so I think I've figured out how to do it. Still not as simple as 98SE had it but I guess it will actually work better this way.
Probably not as simple as 98se, but I gather it is inherently more secure...Originally Posted by rallynavvie
makntraksIn the theater of the mind...
It's always good to know where the exits are...
Lan Drivers
By Soixante in forum ComputerReplies: 7Last Post: 11th May 2011, 19:16 -
stream outside LAN
By alexandros27 in forum Video Streaming DownloadingReplies: 6Last Post: 12th Oct 2009, 08:19 -
Setting up a LAN
By avz10 in forum ComputerReplies: 11Last Post: 5th Mar 2008, 11:56 -
how to limit speed of users on wireless network (router-lan-wireless)
By deejay.2001 in forum ComputerReplies: 5Last Post: 2nd Nov 2007, 23:56 -
5.1 over LAN
By prizi in forum ComputerReplies: 6Last Post: 10th Jun 2007, 14:06
