Just curious what they are used for. I use TMPGEnc to encode, cut, and join mpegs. I noticed them under mpeg tools, but I have never used them. I'm a newbie, just trying to learn about some of TMPGEnc's features.
De-mulitplex takes the audio and video bits of a file and seperates them to two seperate files. Multiplex takes a video file and an audio file and makes them into a single file. A MPEG file with audio and video is called a program stream, audio and video seperately are called elementary strems.
Sometimes when encoding TMPGEnc does a bad job of the multiplexing part, so de-multiplexing (making two seperate files) then multiplexing (putting them back together) can fix the error. -
Thanks for the input, Shabubu. I have a video where the audio and video are badly out of sync (video is about 5 seconds in front of the audio). I downloaded it off the internet and don't know how it was encoded. Would demultiplexing then multiplexing fix this problem?
Conversion or demultiplexing of TRP files
By ranmamez in forum DVB / IPTVReplies: 2Last Post: 26th Oct 2011, 09:50 -
out of sync when demultiplexing
By calanda in forum Authoring (DVD)Replies: 5Last Post: 5th Aug 2010, 02:04 -
General Purpose Video Files
By AndyPerry in forum Newbie / General discussionsReplies: 1Last Post: 28th May 2009, 23:27 -
I need an all purpose converter
By warlock110 in forum Video ConversionReplies: 0Last Post: 3rd Dec 2008, 22:06 -
Best all-purpose format for DVD rips
By studawg66 in forum Video ConversionReplies: 5Last Post: 3rd Sep 2008, 12:49
