I am trying this product out. I like some of the features. However I can not seem to find a way to add background music to a menu page, be it motion or not. Does anyone know if this can be done in this program or should I go with DVD lab?
If I go with DVD lab, does anyone know if the ac3 encoder plugin from TMPGEnc will work on its own or with DVD lab. The website makes it sound like you have to by DVD Author or TPMGEnc 3.0 to get ac3 to work.
You have to make your menu background as a mpg video file. Your music should be included in the mpg file. Even if you want to use a still picture for background, you would have to make it into a mpg with music added. I use my video editing software to prepare the menu background with music.
seems to do this then is adding some extra steps. I'll try it and see if it works for me to do it this way. Thanks for the reply.
So I came home to try out DVD Author and I have 1 movie with 4 chapter points to test this software with, when I creat a menu page I get all my chapter points plus the play button? I am used to using DVD complete which will creat a MAIN MENU page that has a play button or a button to a seperate page for chapter selection. The guide I am using is from afonic DVD guides and it does not explain how to creat a Main Menu. Can this be done with TMPGEnc author or is there a better guide I should be using. I really hate learning new software!!!
I haven't seen a guide for menu creation in TDA. I seem to recall Alfonics guide saying to experiment with the menus or something like that.
I think it's because there are so many variables.
menu problem in TMPGEnc DVD Author 3
By sanduul in forum Authoring (DVD)Replies: 13Last Post: 23rd Oct 2007, 20:20 -
TMPGEnc DVD Author 1.6 thumbnail menu issue
By Bix in forum Authoring (DVD)Replies: 0Last Post: 3rd Oct 2007, 11:00 -
TMPGEnc DVD Author 3 (MENU PROBLEM)
By jaffacaique in forum Authoring (DVD)Replies: 9Last Post: 18th Sep 2007, 20:43 -
TmpgEnc DVD Author 3 - Question About Menu Music
By heyjjjaded in forum Authoring (DVD)Replies: 10Last Post: 30th Jul 2007, 14:16 -
Menu troubleshoot using Tmpgenc Dvd Author
By tekka06 in forum Authoring (DVD)Replies: 8Last Post: 4th Jul 2007, 04:53
