ive started to get the hang of decoding with mplayer but it fails to create a single mpg so ive tried muxing them together but the syncing is terrible,
required(DTS)=2571000
++ WARN: [mplex] Video e0: buf= 233219 frame=000701 sector=00004110
++ WARN: [mplex] Audio c0: buf= 4096 frame=001168 sector=00000342
**ERROR: [mplex] Too many frame drops -exiting
too many frames??
Results 1 to 18 of 18
If it is out of sync then it should be an encoding problem, not a mux problem. Did you change framerate going from source to destination? Did you use "Decode with mplayer" or "Decode with Quicktime"? Which framerate was your source?
[nitpick]Originally Posted by punkface
Almost all DVD players sold in PAL countries play both kinds of discs. These multi-standard players can partially convert NTSC to a 60-Hz PAL (4.43 NTSC) signal. It’s the old/simple tv sets in PAL countries that can’t handle such a signal.
Most NTSC players can’t play PAL discs.
[/nitpick]
XBOX usually delivers Composite Video output + Stereo output. With an "Advanced" cable, users can enjoy RGB video (& optical SPDIF audio).
I suppose you'll have to change a setting in the On Screen Display to switch from Composite Video to RGB.
Assuming that the tv set has a SCART input socket, and supports RGB signal input. SCART can carry Composite, S-Video and RGB, so not all tv sets with SCART are required to accept RGB (but most do). Picture sharpness and colour quality will be noticeably better with RGB.
I think the XBOX SCART output socket is non-standard, so an ordinary SCART cable (with all 21 pins connected (needed for RGB)) is no good. One side of the cable has to fit the XBOX after all. So you'll need the XBOX version of the cable.
AV Out of Sync after Muxing
By hpman247 in forum Video ConversionReplies: 4Last Post: 5th Apr 2015, 00:44 -
muxing to mkv sound drifts out of sync
By jimbobsma in forum Video ConversionReplies: 0Last Post: 18th Nov 2010, 06:17 -
Out of sync issues after encoding and muxing?
By mrjust in forum Newbie / General discussionsReplies: 3Last Post: 27th Mar 2010, 18:06 -
MKV Muxing Audio Out-of-Sync with Video
By Cube11 in forum Newbie / General discussionsReplies: 0Last Post: 26th Jun 2008, 14:27 -
Audio CBR out of sync after muxing + stuff
By Darius_bd in forum Video ConversionReplies: 4Last Post: 11th Apr 2008, 08:50
any other ideas or should i just give up?
