Hi guys i have an svcd which is on 2 discs and i was wondering in dvd lab how i join the segments together to play as 1 film.
No need to "join" them just link the end of the first part to the second part.
What i have done so far is import my 2 sections of the film into movie1 and movie2 so can you tell me mate how i link them together.
cheers mate -
I don't have DVD-lab near, butI'll try to describe it anyway. Look for the link tool. It should look like some kind of arrow on the left side of the storyboard. Then just draw a line from the 1st part to the 2nd part. It sould be really easy. Also try the help inside the program, I'm pretty sure they have a short lesson on how to do a simple disc.
http://www.mediachance.com/dvdlab/Help/index.htm
Look for the chapter about connections.
More dvd lab questions
By sterankin in forum Authoring (DVD)Replies: 12Last Post: 16th Aug 2010, 17:13 -
Help with DVD-lab PRO.
By angles in forum Authoring (DVD)Replies: 2Last Post: 3rd Jan 2010, 18:19 -
DVD Lab question
By sumeshkri in forum Authoring (DVD)Replies: 5Last Post: 13th Nov 2008, 22:32 -
DVD Lab 2 error
By XL3/\/7 in forum Authoring (DVD)Replies: 4Last Post: 3rd Jun 2007, 07:54 -
DVD Lab Help!
By ardiani in forum Newbie / General discussionsReplies: 14Last Post: 25th May 2007, 08:52
