I've authored a DVD with 3 tracks, all using the same movie fragment but :
track 1=LPCM audio
track 2=AC-3 audio
track 3=mpeg audio
I've used DVD2AVI to get video and audio, then tmpgenc to make the new video and multiplexed stream for nr 3. Then tmpgenc DVD author to author the disc.
The problem is that all 3 tracks play fine on a PC (SW) DVD player,
On the standalone player (Sony DVP-305NS), all is fine except track 3 has no audio.
I made sure sampling rate is 48 KHz
what could be the reason ??
1: Sony DVP-305NS does not support mpeg 1 layer II audio ??? (it is a regio 2 player..)
2: I should not let tmpgenc do the audio/video multiplex.. I should do this in DVD author ??
3: other..
4 : do not bother, just use the AC-3 audio, which is less work and more bang for the bits...
Thanks for any helpful hints !
The problem could be your "#1".
Maybe MPEG1, LAYER II audio is not supported by your player. Your best bet would be to re-encode the third track to .AC3. AC3 is compatible everywhere.ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
thanks for your opinion.
note : the Sony DVP-305NS plays VCD ok. I thought VCD audio is the same mpeg 1 layer II ??
It is in fact because I am happy with the VCD audio quality, that I want to author the DVDs with this kind of audio..
Bye
Burned blu ray on standalone player, I have audio but no video
By BAMFstang in forum Authoring (Blu-ray)Replies: 2Last Post: 19th May 2010, 13:28 -
HT - dvd player in the pc or a standalone?
By Haopengyou in forum Media Center PC / MediaCentersReplies: 5Last Post: 6th May 2010, 07:39 -
no audio in divx files on standalone player
By kaston in forum Authoring (DVD)Replies: 14Last Post: 27th Oct 2009, 21:26 -
[SOLVED]Audio won't play for an AVI file in my standalone DivX/XviD player!
By =CrAzYG33K= in forum AudioReplies: 4Last Post: 13th Oct 2008, 08:32 -
no audio on iDVD-burned DVD when played on a standalone DVD player
By patroklus in forum MacReplies: 12Last Post: 10th Apr 2008, 12:56
