Everything was going peachy with my DVD-ROM drive. I had just upgraded the computer and started burning with it again, when Windows Update decided to tell me I needed to install some "critical update" for FrontPage Server Extensions. Okay, I thought, I actually use FrontPage, so why not. So I install the update and then never give it another thought.
Then I tried to burn something onto a DVD-R, and all hell breaks loose. Lead-ins are taking two minutes to write, and DVDDecrypter just spits the dummy. The following is just one of the error messages I get:
Results 1 to 15 of 15
"It's getting to the point now when I'm with you, I no longer want to have something stuck in my eye..."
lead-in that long sound like it's writing at 1x. check what transfer mode your drive is using now.
I was writing at 4X, and it doesn't even get past the lead-in.
I have NFI how to do that."It's getting to the point now when I'm with you, I no longer want to have something stuck in my eye..." -
hold the windows key down and press break. hardware - device manager. ide/atapi controllers - primary - properties - advanced - transfer mode. check what it says on primary and secondary device, device 0 and device one.
Both say "DMA if available".
Is this the problem?
It has just come back with yet another random error message, now saying "Interpretation: No seek complete"."It's getting to the point now when I'm with you, I no longer want to have something stuck in my eye..." -
no, DMA is what we want. i take it you've googled for problems associated with the update?
do you have any other burning software you can try? is dvddecrypter still ripping normally? -
B's Gold Recorder won't play ball, and neither will Nero.
I have never used System Restore before."It's getting to the point now when I'm with you, I no longer want to have something stuck in my eye..." -
HI,
I was just reading your post. I used System restore and it completely fixed my problem. It was about a year ago and i did something similar to hwat you did and downloaded an update for another program I had and all hell broke lose. The system restore feature will just bring your computer back to the state it was in beofre you performed that update. (or whatever date you choose for that fact) I'll let the experts on this forum give you more tech advice. Just my 2 cents.
Marc -
Tried system restore. The problem is still there, and the error messages still cycle through about five or six choices, all variant on the one I have already posted. I am backing up my files and getting ready to rebuild the computer.
there you go, lesson learned. never install an update unless you're experiencing a problem.
Problem with that is that I am always experiencing problems with Windoze. It's like the two go hand-in-hand.
I may be absent for a while whilst I reinstall the contents of my hard drive yet again.If it fixes my problem, however, then I will be quite pleased about it.
Well, I just reinstalled everything, and it still refuses to work, spitting out the same error messages. So it appears the drive is bust after a mere few months' use. I am beginning to understand why some people have so little faith in technology. Maybe it is time to complain to LG...
have you tried disconnecting the drive, booting the machine, shut down, reconnect, and reboot?
Yes, tried that. Given that I can connect a Pioneer DVR-107D to my computer and it works perfectly, I think I know what the problem is. When I bought the drive originally, it was heavily discounted as it was no longer the most current model. I suspect something in its inner workings has seized up, so I am going to start going to the retailers and demanding an explanation.
Need Help Urgently Capturing from SVHS VCR
By Hairykiore in forum Video Streaming DownloadingReplies: 9Last Post: 4th Aug 2011, 19:26 -
encoding .3GP. Need help. Urgently.
By navand in forum ffmpegX general discussionReplies: 2Last Post: 6th Jul 2011, 14:35 -
Help needed URGENTLY!!! "download DBCodec"
By Liaaggelou in forum Newbie / General discussionsReplies: 3Last Post: 8th Jun 2010, 12:40 -
Authoring Help Urgently Needed
By AlanSibley in forum Authoring (Blu-ray)Replies: 11Last Post: 3rd Dec 2008, 01:20 -
new here how do i setup tbc AVT-8710 Urgently
By effects in forum RestorationReplies: 7Last Post: 6th Jul 2007, 13:21
