  1. i've been trying all day and have run into 2 major problems
    i've followed the steps here
    https://www.videohelp.com/forum/userguides/166237.php
    to the tee
    i'm having my first problem with the audio conversion with besweet i get it all set and i hit mp2 to mp2 and nothing happens nothing!!!!
    (btw i've looked on this site for a users manuel for besweet and i can't find one)
    so i figured i'd skip it for now and move on to the next step then i'd go back fresh
    second problem
    dvd2avi when i try to load the d2v file tmpgenc cannot open or unsupported
    i'm alittle steamed right now so please forgive me but i'v wasted a a great day messing with this i'm at the end of my rope so i'm hoping someone here will take pity on me and please tell me what i missed again i followed the guide to the tee so i don't know
    i am a newbie to this but i do know how to read and follow instructions so either the guides wrong or i'm just missing some small part
    (deep breath)ok i feel better now thxs for letting me vent i guess what i'm trying to say is please help me
    thxs all
    i have msn messenger cjbabyy@hotmail.com
  2. Member underwurlde's Avatar
    May 2004
    S.England
    Hello!
    I have found in the past (2 years) that anything video related on a PC is overly complicated. There never seems to be a standard way to do things and like
    you I spend days trying to get various programs work together (so you may be heartend by the fact that you are not the only one who gets totally frustrated). I
    usually find that if the video works, the audio screws up, if the audio works then the video screws up & if they both work then they will be out of sync!
    To me things like this should just work. After all, it's not bloody rocket science is it? Or is it???
    Anyway...
    i) BeSweet is a DOS program, driven via the command line in a DOS session. I usually constuct a batch file to do this for me. For me the GUI extension for
    BeSweet just constructs the command line for you (& hence no real need for any help files), it doesn't seem to actually RUN the program for you (I have found
    that you have to run it in a DOS session). Usually BeSweet will then just do it's stuff - I have found it to be an excellent little program that deals with many
    audio files that other programs just cannot handle.... That said I have had a few minor problems with it.
    ii) When video programs report 'cannot open or unsupported' (assuming you have pointed correctly to the source etc) then this usually means that you are
    missing a CODEC & hence the 'unsupported'. Also, Codecs do clash so be careful!
    iii) A useful little program called GSpot can help unearth any Codec problems - just drop the problem video file onto it...
    iv) Follow this codec installation guide: http://forums.afterdawn.com/thread_view.cfm/48608
    v) May seem like a daft question but what is your source video file you are trying to convert? Have you ripped it from somewhere? If so how?
    Hope this helps!
    Andy
    Work you bloody thing....
  3. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    Convert your MP2 audio to WAV first. Then convert from that WAV to a new WAV doing the FPS change. Then you can convert your time corrected WAV back to MP2 if that is what you need as your final audio format.
    BeSweet seems to work best doing the FPS change when you go from WAV to WAV.
    - John "FulciLives" Coleman
    P.S.
    Some versions of DVD2AVI are "buggy" so be sure to get the latest version which should (knock on wood) be OK. If TMPGEnc still won't load the D2V project file then you need to look into your ENVIRONMENTAL SETTINGS ... their is a TAB called "VFAPI plug-in" and there should be something in there regarding DVD2AVI ... raise the priority level ... should do the trick.
  4. yes it does help and thxs andy for lettting me know it not just me
    i still didn't get it and i don't think i will so i'm giving up on this besides the wait for movies to dvd's is getting smaller each day
    so instead of aggraviting myself with 600 different programs just to watch an 1 and1/2 movie
    screw it
    thxs again andy and FulciLives i'm sorry for wasting your time
