hi can some 1 plz help me with a problem with nero??? im trying to burn 4 mpeg eps to make a vcd which i converted with TMPGEnc Plus...those 4 eps are 75mins and 770megs ... the problem is when i drag and drop them in nero it say i dont have enough disk space b/c my cd is only 80mins/700megs how can i adjust it so it will display minutes and not mbs? thx....
i know this work b/c i have over 50cds with 4 eps on all fo them....i havent burn eps in a long time so i dont know what im doing wrong plz help
That won't help. You can try clicking on File then preferences thenhow can i adjust it so it will display minutes and not mbs? thx....
clicking on the expert features tab. Make sure 'enable overburn disc'
is checked and change the minutes box below to 99.
When burning, do not select track at once (TAO) but rather DAO.
It will still warn you about the size but then should continue
regardless. You will be doing what is called 'overburning'
Nero will burn 4X, DVD Shrink-Nero only 2.5X
By happydog500 in forum DVD RippingReplies: 16Last Post: 4th Jan 2010, 20:49 -
Nero Recode 3.1.2.0 -- "Nero Digital Standard" vs. "Nero Dig
By GrayStrickland in forum DVD RippingReplies: 1Last Post: 15th Dec 2008, 20:23 -
Nero vision VCD autoplay
By Aliyans in forum Authoring (VCD/SVCD)Replies: 8Last Post: 31st Dec 2007, 11:54 -
need help with Nero 8 and Nero Vision 5 (figuring Extended Play Plus)
By Edward Benavides in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2007, 12:10 -
consolidate vcd files with Nero Vision, but problem with playback
By slh888 in forum Newbie / General discussionsReplies: 3Last Post: 27th Jul 2007, 18:36
