how do I do this? the probelm, was, I originally thought, a syncing problem. Until I looked at the file and listened to it. Now I'm convinced that some of the sound had dropped then quickly picked back up. I tried everything I could in virtualdub. Musicmatch can make audio, but how do I add that audio to virtualdub? my new plan is the following:
1) capture video (no audio)
2) capture audio in musicmatch
3) add audio from MM to the video using VD.
number three is where the problem is. I've been trying to solve my video problems for a couple years now. the best I have been able to do before VD was windows movie maker. Everything else is fine. it's this little audio problem.
Any thoughts? your help is appreciated!
Load the video (drag n' drop) then under audio select Wav Audio and add your audio file, set both audio and video to Direct Stream Copy then under file Save Avi.
I have a problem with mp4 files in virtualdub, slow motion audio.
By barbur in forum Newbie / General discussionsReplies: 5Last Post: 12th Feb 2012, 13:16 -
DubIt Audio Editor - Adding sounds to Video Files
By devilcoelhodog in forum Newbie / General discussionsReplies: 0Last Post: 27th Sep 2011, 16:54 -
Confusion with DGIndex, AviSynth, VirtualDub and audio files
By fatcharlie in forum Newbie / General discussionsReplies: 10Last Post: 1st Mar 2011, 15:49 -
problems with adding the sub file on VirtualDub
By yuunhaa in forum SubtitleReplies: 7Last Post: 25th Feb 2010, 11:39 -
Virtualdub error with DV files - Audio Samples not found in source
By kbehel in forum Video ConversionReplies: 4Last Post: 30th Mar 2008, 03:40
