  1. I'm trying to rip Gothika,and about half way through (using clad dvd) it stops ripping and starts frameserving. Does anyone know what could be wrong?
  2. Member tweedledee's Avatar
    Oct 2002
    Melbourne Australia
    Try a good ripper i.e. DVD Decrypter.
    "Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey
  3. I'm a Super Moderator johns0's Avatar
    canada
    Its proly reading the ifo wrong and starting its process to early,try using dvdshrink instead if you are going to copy it to one dvd.
  4. Thanks for your help
    I used dvd decrypter also, but need a link on how to frameserve it to go in tmpgenc. I use clad dvd because its so easy.
  5. Member tweedledee's Avatar
    Oct 2002
    Melbourne Australia
    So you don't want to copy a back up? What do you want to do?
  6. i'm making a vcd
  7. Member tweedledee's Avatar
    Oct 2002
    Melbourne Australia
    If it was me, my next step after ripping would be DVD2AVI, then TMPGEnc.
  8. thanks, I'll give that a try. It seems like the quality is better that way anyway...just slower.
