Using DVD-Lab, I went ahead and set up very specific chapter markers in a certain movie. Since then, I have re-encoded the same footage with more care to preserving quality. The new encode is identical in length to the original.
What I want to do is remove the original encode from the movie project and replace it with the new encode. Well, deleting the video file from the movie project results in everything disappearing. And dragging the new video over the original does not produce a replacement dialogue.
What are my options? It would be quite an extensive and wasteful project to re-do the chapter positions, especially since that particular aspect of DVD-Lab is atypically unintuitive and tedious. (No text list entry option, no way to save chapter marker data, etc.)
right-click on the Chapters bar above the movie, you will have an option to Export Chapters to a .txt file, which you can then import the same way once you have replaced the movie.
- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
Thanks.
I'll take any solution I can get, even a roundabout one.
How is that a roundabout solution? It's your only one in this instance.
The "roundabout" way would be to write down with pencil and paper every chapter mark and then manually add them back in. -
I'm with Andkiich - how roundabout is it to right click and export? and the fact that it saves to a .txt file, and allows you to import .txt files of chapter timings, makes this statement:
a bit of a puzzler to me.Originally Posted by Colmino- housepig
Housepig Records
out now:
Video format with chapter markers?
By whoisquilty in forum MacReplies: 9Last Post: 25th Mar 2011, 18:29 -
Adding Chapter Markers
By Big Jake in forum Authoring (DVD)Replies: 11Last Post: 12th Sep 2010, 00:50 -
Want to keep chapter markers with Vob2MPG in single mpeg
By Pontyac in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 8th Jan 2010, 13:14 -
AVI to DVD with chapter markers?
By cleantone in forum ffmpegX general discussionReplies: 1Last Post: 18th Oct 2007, 04:26 -
Toast 7 - Chapter Markers from iMovie
By Surfmaster in forum MacReplies: 14Last Post: 3rd Jul 2007, 14:43
