I'm using TMPGEnc v2.59.47.155 Plus. When i'm using the Project Wizard and I select my source file I get the error 'File "C:\AVSEQ01.MPG" can not open, or unsupported.' I've tryed searching google and tryed methods others have suggested but none of it is working. Any help would be appreciated.
Regards.
Run it thru with VCDGear and check that box says ' fix mpg error'. And run it thru TMPGEncPlus again to see if it work.
make sure you got the right mpeg-2 codec installed and also make sure that your mpeg-2 from the svcd is filtered correctly. Best way to rip it is with isobuster
Thanks for the replies. vcdgear solved the error, but now when I try to add my file as the video source in the project wizard, the hard drive is busy for about 10 seconds, then the hard drive light just flashes about once every five seconds. I waited 15 minutes and it still hadn't loaded. Any ideas?
Regards. -
How would I use DVD2AVI to do it because i'm trying to convert SVCD to DVD
Also how long should TMPGEnc take because it must have been going 30 mins+ atm. I'm using 3 files with the "Open sequence files as a movie" option so it's about 2.2GB total.
Regards.
Just tryed leaving it run for an hour, still nothing. TMPGEnc is listed as 'Not responding' in Task Manager as soon as I try to add it. Am I doing something wrong?
Problem with TMPEnc DVD Author 3
By ebadillab in forum Authoring (DVD)Replies: 11Last Post: 28th Jul 2009, 06:23 -
Progressive AVI encoding to DVD in TMPEnc - interlaced?
By Xoanon in forum Authoring (DVD)Replies: 16Last Post: 9th Jan 2009, 11:01 -
error encoding while converting avi to svcd
By joannekhow in forum ffmpegX general discussionReplies: 4Last Post: 1st Oct 2007, 11:41 -
error in tmpenc
By php111 in forum Newbie / General discussionsReplies: 4Last Post: 4th Aug 2007, 07:56 -
Problem with TMPEnc
By Technophobe in forum Video ConversionReplies: 3Last Post: 28th Jul 2007, 16:44
