Hi all. I want to take a video file directly off of a dvd and convert it into an mpeg for later burning on another disk.
I followed the directions here on the site to extract the video file I want off of dvd decryptor. The following files were extracted:
VTS_02 - Stream Information
VTS_02_0.IFO
VTS_02_1 - 0x80 - Audio -AC3 2ch - 48kHz - DRC - DELAY -66ms.AC3
VTS_02_1 - 0xE0 - Video - MPEG-2 - 704x480 (NTSC) - 4~3
VTS_02_2 - 0xE0 - Video - MPEG-2 - 704x480 (NTSC) - 4~3
I didn't make this home video disk, but are there two separate video entries for the video I have extracted, or is this normal?
There is one audio clip, not two. With the two video clips, one ends right where the second begins. I tried to merge them with tmpgenc, but I was told that the second video file was not an mpeg file.
Any ideas?
Thanks in advance.
Read the DVD section to the left. This is a matter of you understanding how the DVD structure works.
www.videohelp.com/dvd -
Apollo1980,
Can you tell us more in detail?
What exactly you wanted to do? Why convert to MPG if you just want to make a copy? -
The reason I want to extract to a mpeg is so that I can:Apollo1980,
1.) Edit out some things I don't want
2.) Reburn with a better menu system, and possibly with other videos.
Once I have an mpeg that I want, I'll reauthorize and burn. -
Could it be that a proper header is missing on the second m2v file? If so, what do I do to get it back?
Copying DVD's with Shrink and decryptor
By LeeRobertE in forum DVD RippingReplies: 6Last Post: 26th Feb 2011, 15:46 -
DVD Decryptor with newer protection schemes?
By Huh...What? in forum DVD RippingReplies: 7Last Post: 26th Aug 2010, 09:34 -
DVD Decryptor Error Massage
By pchan in forum DVD RippingReplies: 13Last Post: 18th Jun 2009, 14:37 -
SONY AW-Q170A Ripping tops out at 3x with DVD Decryptor
By alwayssummer in forum DVD & Blu-ray WritersReplies: 3Last Post: 29th Oct 2007, 19:08 -
Time to finally put DVD Decryptor to bed...at least for Liteon recorders...
By oldfart13 in forum DVD & Blu-ray RecordersReplies: 5Last Post: 4th Oct 2007, 13:55
