I am trying DVDRebuilder with CCE SP for the first time and I keep running into the same problem. Whenever I try to "Encode" I am keep getting an error window that says "Can't open ecl file" Can anyone help me out here I am very confused? TIA
Results 1 to 16 of 16
Download eclcce
Run EclCCE.exe
It will ask for the path of cctspt.exe
(C:\Program Files\Custom Technology\CCE SP Trial Version\cctspt.exe)
DVD Rebuilder - Options - Setup - Path to CCE SP (New):
C:\.......\eclcce\EclCCE.exeYou stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
Thanks so much for your reply. I downloaded it, but when I click on the EclCCE.exe CCE opens. Is that correct? I ask because I cant find where it asks for the path
Try deleting the EclCCE.ini file in eclcce folder then try again
Ok. Thanks again. Now I get a popup window that reads
"c:\backup\D2VAVS\item.ecl" is not an ECL for CC-SP" -
What did you do exactly?
What version of CCE and eclcce are you using?You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
After Preparing with DVD-RB a CCE window pops up than I get the error window. The versions I am using are CCE SP Trial Version 2.67.00.10 and EclCCE 2.67.0.27. Thanks a lot for your replies I am really stuck here
What did you do exactly after deleting EclCCE.ini file ?
Whats the "Path to CCE SP (New)" in DVD ReBuilder ?
It is pointed to the C:\Program Files\Custom Technology\CCE SP Trial Version\EclCCE\EclCCE.exe
path to MPEG2DEC3DG (in RB setup) ?
CCE Options set to CCE SP (v2.66+) ?
AHhh! Actually I had it set to CCE Basic v2.67
and my MPEG2DEC3DG path is
C:\Program Files\Avi Syth 2.5\plugins\MPEG2DEC3DG.dll -
That was the problem thenOriginally Posted by Chip718You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
Does dvdrebuilder use multi cores?
By the_man_one in forum Authoring (DVD)Replies: 4Last Post: 16th Jul 2010, 00:25 -
No audio tracks (DVDRebuilder)
By stiltman in forum DVD RippingReplies: 3Last Post: 11th Nov 2008, 22:45 -
Is it possible to change the way DVDRebuilder assign feature and extras?
By Talayero in forum DVD RippingReplies: 3Last Post: 8th Mar 2008, 13:41 -
DVDRebuilder
By santino_avi in forum DVD RippingReplies: 5Last Post: 20th Jan 2008, 15:03 -
Please suggest which is better DVDShrink or DVDRebuilder?
By leinan in forum Newbie / General discussionsReplies: 4Last Post: 12th Jul 2007, 21:00
