NEC drive was working wonderfully. Burning well with no coasters using TDK 4x +r media. Recently bought a spindle of Ritek G04 -R media. When i put one into the drive (have tried many from the spindle), the drive doesnt recognize that any media has been put in. I went to dvdinfo to try and test the media and it says "NO Media Present". I am using Herries latest firmware and have tried three different versions with the same problem. My drive is in an external enclosure through usb 2.0. I have tried uninstalling and reinstalling the drive with no success. Any idea how I can get this practically brand new drive to recognize media again. Thanks in advance for the help.
Josh
Have you tried fully powering off the external drive after flashing the firmware ?
I use a nec2500 and always use Ritek G04 media with no problems. Watch the nec 1.07 firmware as I no longer can burn my Ritek G05 media at x8. I could before flashing from 1.06
Hope this helps,
Manuforti -
Use firmware revision 2.15 (for the NEC ND-2510A) for the best results with RITEKG04/RITEKG05 on the NEC ND-2500A. Herrie has made a version that will readily flash onto the ND-2500A, called 1.07v2b6.
Regards,
TerminalVeloCD -
Hi m8
I had the same problem after flashing the firmware so i took it out of the external enclosure fitted it in the pc and reflashed the firmware it worked ok so i put it back in the external enclosure and it works fine now hope this helps...
Burner Won't Recognize Blank DVD-R Discs
By ddowden1 in forum DVD & Blu-ray WritersReplies: 11Last Post: 23rd Aug 2009, 07:52 -
NEC ND-3500AG DVD RW DL burner doesn't recognize blank DVD's
By renegade431 in forum DVD & Blu-ray WritersReplies: 38Last Post: 8th Feb 2009, 07:16 -
Suddenly, burner doesn't recognize blank DVD
By slats7 in forum ComputerReplies: 9Last Post: 13th May 2008, 12:10 -
MAJOR probs w/ my NEC 2500A
By candlelight in forum DVD & Blu-ray WritersReplies: 25Last Post: 5th Sep 2007, 15:19 -
Ritek Ridata DVD-R 4X G04 where or better?
By Illicious in forum MediaReplies: 8Last Post: 15th May 2007, 11:41
