i know this sounds stupid, but can i put like 2 different VIDEO_TS folders on a dvd, and select which one for my standalone dvd player to read?
errr....NO....
Don't be silly. That's what Menus and Titles are for 8) -
I think what you mean is is there a way to put 2 movies on 1 DVD-R and YES there is but you need to compress BOTH MOVIES with the likes of DVD2ONEX and then re-author with something like TFDVDedit (Still UNBELIEVABLY Expensive for a program less than 5 MB in size IMHO) and there are other ways but more complicated.Originally Posted by peacefrog226
So in short the answer is YES and a little research goes a long way.
regards
LoopholeThere is ALWAYS a loophole!!!! -
You judge the worth of an application by its size? Thats stupid.Originally Posted by LoopholeIf it isn't broken, take it apart and find out why.
blog: deadsierra -
No stupider than answering, So in short the answer is YES and a little research goes a long way.Originally Posted by deadsierra
To the question, Can i put like 2 different VIDEO_TS folders on a dvd, and select which one for my standalone dvd player to read?
So, I'm always open to new ideas. Someone please explain to me how this,
Found here: http://www.tfdvdedit.com/
Allows you to place two VIDEO_TS folders on a DVD and choose which one to play at Disk startup.
I'm not going to spend much time on something I'm obviously not going to buy, but, it appears that this uses DVD Studio Pro2, which I already own, to build a DVD in the standard format. Which is something like;
DVD
VIDEO_TS Folder
Menus and Titles
Which kinda, sorta, is implied by the statement, That's what Menus and Titles are for.
I agree, this software is highly expensive for someone who's completely satisfied with DVD Studio Pro 2.
If you are going to compress two movies with dvd2onex, it's probably easier to just do movie only and then use something simple like sizzle to put a simple menu to choose which of the two movies you want to watch. I don't think anyone is going to be using a $700 program for something this trivial.Originally Posted by Loophole
How to code Multipe Subtitles on MP4 from VOB files
By 1337assassin in forum User guidesReplies: 0Last Post: 16th Oct 2010, 11:27 -
VIDEO_TS 7GB to VIDEO_TS 4GB
By klemyz in forum ffmpegX general discussionReplies: 2Last Post: 9th Dec 2009, 13:43 -
VIDEO_TS to AVI and (maybe) back to VIDEO_TS
By macbuz in forum MacReplies: 2Last Post: 16th Jan 2009, 20:40 -
Video_TS and DVD
By faizy999 in forum Authoring (DVD)Replies: 2Last Post: 17th May 2008, 12:32 -
VIDEO_TS to mpg to VIDEO_TS
By Mållgan in forum EditingReplies: 9Last Post: 29th Jan 2008, 15:53
