quick question regarding some issues I'm having with burning my home movies. I'm using a dv camcorder and capturing the video with Ulead Videostudio via Firewire. This is where I get a strange problem as it captures, I can see the video on my monitor and I notice that when a person is still, it is clear...if they begin to walk or run, the edges of the person become jagged.
The remaining process is I encode the video only to m2v using TMPGEnc. I use virtua dub to extract the sound to .wav and then use FFMPEG to convert it to .ac3. Finally I use TMPGEnc DVD Author to create the Mpeg and then burn the final product using Nero. The final output is crisp except for the motion part, I still get the jagged edges when there is alot of motion on the screen.
I should note that when I hook the camcorder up directly to the tv, it is perfect, so the problem seems to be the capturing process, but I am not sure what I am doing wrong? Any help is greatly appreciated as this is my only problem, everything else seems to work perfectly. Thanks!
Try encoding a sample portion using the inverse telecine setting.
Hello.
Edges look jagged, and lines across the video.
By killerteengohan in forum DVD RippingReplies: 18Last Post: 29th Jul 2011, 14:18 -
Why does this x264 encode from DVD have these jagged edges?
By Obelik in forum DVD RippingReplies: 7Last Post: 17th Apr 2010, 01:59 -
Jagged edges on buttons
By motown01 in forum Authoring (DVD)Replies: 1Last Post: 21st Oct 2009, 12:40 -
Is this a video Codec issue? The videos have jagged/rough edges (PIC) Incl.
By Ricky_S in forum Newbie / General discussionsReplies: 11Last Post: 30th Sep 2009, 20:57 -
Procoder 2 - Jagged Edges
By pbar in forum Video ConversionReplies: 4Last Post: 24th May 2007, 10:32
