i converted 2 svcd clips to dvd, they play fine but dont have n e chapters, i converted using svcd2dvd and selected that i wanted chapers every 5 minutes, but i have none, the dvd also wont fast search, is there something i can do to make it fast search and add chapers?
cheers in advance
Yep, one way is to downlaod a free 30 day trial copy of tmpgenc DVD Author.
Drag the mpg's into that and, under edit clip, either auto add chapters
every 5 minutes or select the exact frames you want a chapter to start.
The above program will also correct your inability to fast forward
and reverse. There are other popular programs that can do
the same job such as:
DVD Lab (shareware)
Ulead Movie Factory (30 day full working trial)
Nero Recode (30 day full working trial)
-see tools on the left hand side to read about these programs
and more. -
DVD Movie Factory is a pretty good choice as well.
It allows Auto-generating the chapters or you can define points in the movie to create them... thumbnails (motion if desired) and all
HTH
Chapters no longer work after adding audio to DVD.
By Nagashi in forum DVD RippingReplies: 4Last Post: 25th Jul 2010, 18:27 -
Adding chapters to .pm4 video to burn to dvd ...
By CaptainChaos in forum Authoring (DVD)Replies: 2Last Post: 13th Sep 2009, 06:54 -
Adding chapters to DVD project in TMPGENC DVD Author
By robertazimmerman in forum Authoring (DVD)Replies: 4Last Post: 26th Jan 2008, 11:09 -
Adding chapters in TMPGEnc DVD Author 3 with DivX Authoring?
By T_virus in forum Authoring (DVD)Replies: 3Last Post: 30th Dec 2007, 20:53 -
adding chapters to a dvd
By loa909 in forum Newbie / General discussionsReplies: 1Last Post: 3rd Sep 2007, 09:02
