Hi, trying to use IfoEdit I:
Start IfoEdit -> Selecct 'Dvd Author' -> Select 'Author New Dvd' -> get file selection boxs for selecting separate video (m2v) and audio (various formats) streams.
Does IfoEdit allow selection of mpg file(s), or do they have to be decomposed first? Thanks,
CrytalDon
Outstanding! Tried it, but....it doesn't recognize my video stream.
This is a stream that's been captured from a ReplayTv (similar to TiVo, not very standard).
It works fine on a stream that's been ripped from a dvd though. On my file it plays in the preview window, but when I try the demux, it doesn't do anything. It just closes the audio file save window and returns to the main display.
Thanks anyhow.
CrystallDon -
Have a look at this free tool - I think this may do what you want...
https://www.videohelp.com/tools?tool=517#comments -
Thanks again, but no luck. That tool requires a connection to a Tivo box. I have a ReplayTv. ReplayTv has a similar tool called DvArchive, that connects and moves files around, but no authoring. I was hoping TyTool might do some things without connecting, but no dice. I'll keep looking!Thanks again,
CrystalDon
mic input -realtime denoise -> sent as input to dragon naturally speakin
By logicom in forum AudioReplies: 0Last Post: 27th Sep 2009, 12:46 -
How do I know what codec I require?
By samoyed in forum Newbie / General discussionsReplies: 19Last Post: 14th Feb 2009, 01:49 -
Joining Elemental Streams in DVD Lab Pro
By SCDVD in forum Authoring (DVD)Replies: 19Last Post: 10th Apr 2008, 16:51 -
Subtitle Input string not correct format/Input subtitle file error (SOLVED)
By Webgirl in forum SubtitleReplies: 8Last Post: 13th Mar 2008, 09:59 -
I require assistance with a layout, please.
By Zynn in forum Authoring (DVD)Replies: 3Last Post: 5th Feb 2008, 09:39
