I have Pinnacle Studio 8 software and a ton of downloaded video that I'd like to convert to DVD. My first attempt was with a MPEG file as I thought it would be the easiest. I imported the video into Studio, made my menu and scenes. In the preview everything seemed fine so I set it up to burn and let it go. After it was done I popped the DVD in and it seemed to work fine. It went to the menu and I started the video. It plays fine for a few minutes then all of a sudden the video goes completely green. The audio is there but no video. I can't figure out what's wrong as I've checked all of my settings. I'd like to use Studio 8 for this mainly because it is just so easy to import files, break up into scenes and burn. I'd be open to other recommendations foe software though. Thanks.
Results 1 to 1 of 1
pinnacle studio 14, more light in a video?
By computer4 in forum EditingReplies: 3Last Post: 16th Jan 2012, 09:02 -
Pinnacle Studio is unable to connect to your video device
By Amyshubby in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 26th May 2009, 06:30 -
Pinnacle Studio 11 - Problem with cropping video
By mjkamish in forum Newbie / General discussionsReplies: 2Last Post: 28th Dec 2008, 16:51 -
Pinnacle Studio+ 10.7 interlaces my video after 250 frames ?
By blewyn in forum EditingReplies: 1Last Post: 8th Jun 2008, 22:56 -
Pinnacle Studio produces horizontal lines on encoded video
By Grunberg in forum Video ConversionReplies: 2Last Post: 30th Jan 2008, 18:45
