I have an xvid avi file that according to Gspot has ac3 at 192kb/s (96/ch stereo). If I demux the audio with VirtualDub, convert the video with TMPGEnc to mpeg2 and then import both the audio and video into TMPG DVD Author, will this result in a dvd with stero, surround or 5.1 sound? Or is it just as easy to convert the whole file with TMPGEnc directly?
Kal
Kal
if you don't change the ac3 stereo it will be ac3 stereo and you don't if you just demultiplex it with virtualdub(you may have to fix the ac3 with ac3fixgui).Originally Posted by younso
Do not quite follow. What should I do first?Originally Posted by Baldrick
kalKal
Avi to Ac3 user guide. How to encode the audio from an avi to ac3 .
By freebird73717 in forum User guidesReplies: 5Last Post: 9th Dec 2009, 22:53 -
Convert AVI with H264 and AC3 to AVI with XVid and AC3
By ashwin.terminator in forum Video ConversionReplies: 4Last Post: 26th Jul 2009, 12:17 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 20:22 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 11:24 -
converting mpeg2/ac3 and avi/ac3 to avi/lambmp3
By corumz in forum Video ConversionReplies: 2Last Post: 17th Sep 2007, 10:32
