  1. Hello
    I'm new here and i have a problem when converting AVI to DVD using DVD2SVCD:
    after i have brun the movie' when i play in on my DVD, the second subtitles row in two low...olmost out of the screen...
    i ues this guide to config the software:
    http://club.cdfreaks.com/lite/t-61142.html
    i have convrted one movie to DVD before but i didnt use DVD2SVCD, and i have converted a lot of movies to VCD before Using DVD2SVCD.
    What can i do to fix the problem?
    Thx
    just change the positions of the subs(the y position). use the preview to check so it looks okey.
    lower the ext y pos.
  3. But in The prievew its ok this way too...
    your tv will cut the picture a bit, called overscan so you must put the subs kinda high.
  5. can you tell me where exacly?
    i am doing a NTSC
