hi, I wanna know if there's a way to change the audio from a dvd.
Here's what I did: I created a dvd on Ulead's dvd workshop with files created on TMPGEnc, the videos are mpeg2 and the audio is PCM, I have a trial version of the dvd workshop so I can't create AC3 audio, anyway, the dvd I created doesn't fit on a dvd+r and I don't wanna reenconde it 'cause the quality isn't that good to begin with, so i'm wondering if I convert the PCM to AC3 is there a way that I can replace the PCM from the dvd to an AC3 file? is this possible? something like muxing the audio but how can I do this a way the dvd is still playable? Or is that even possible?
Thankx in advance.
If you want a smaller audio stream try converting your PCM to MPEG L2 audio.
Try the Womple MPEG Video Wizard and it will keep the video the same while converting Audio from LPCM to MPEG1L2...
Keep in mind that compatibility for MPEG1L2 is a tad less than PCM on set top machines. (I have never run into a problem)
Shrinking entire dvd with pcm to ac3
By emodio80 in forum Newbie / General discussionsReplies: 29Last Post: 26th Jul 2011, 05:17 -
For Developers ; Video Sample having TWO AC3 and PCM, with en-SUB
By Bonie81 in forum Latest Video NewsReplies: 1Last Post: 13th Oct 2010, 01:30 -
replace ac3 2ch with ac3 5.1 ch in mkv (and sync)
By umbbra in forum AudioReplies: 1Last Post: 12th Jun 2010, 05:18 -
Convert PCM to AC3???
By ivano09 in forum Video ConversionReplies: 6Last Post: 17th Feb 2010, 13:08 -
PCM vs AC3
By Reading Bug in forum AudioReplies: 14Last Post: 1st May 2009, 05:34
