After using DVD Decrypter in IFO Mode for demuxing the main movie I end up with 4 files: *.txt, *.ifo, *.m2v and *.vob.
My question is why I got a *.vob file instead of an *.ac3 file or *.wav file? The original audio of the dvd is in ac3 2 ch, how I know if it is dts or dolby digital? how can I convert the *.vob file for editing the audio? Do I need the *.txt and *.ifo files if I want to re-author the DVD? What is the purpose of these files? Too many qustions for answer, thank you for your help!!
The M2V is your video. I would say that for the audio you had Direct Stream Copy selected instead of demux. If you are editing, chances are you will end up loading your video and audio back into an authoring program, in which case the IFO files are not required. What is in the text file ?
If in doubt, Google it. -
I got it...
1) extract the audio ac3 2ch with VOBedit from the .vob file generated by DVD Decrypter
2) convert the ac3 file to .wav with Ac3Tool
3) open the .wav with CoolEdit 2000 and edit it (increase volume)
Next, I will use TMPGenc DVD Author to load the .m2v and .wav files to re-author with no re-encoding and no quality lost.
I think there's no quality lost. Am I wrong?
Thank you for your reply.
The *.txt file contains only the following text:
0x80 - Audio - AC3 / 2ch / 48kHz / DRC / LBA: 95 / PTS: 00:00:00.218 / Delay: -2ms
0xE0 - Video - MPEG-2 / 720x480 (NTSC) / 4:3 / LBA: 2 / PTS: 00:00:00.220 / Delay: 0ms
I still don't know for what reason is the *.ifo file?? -
The .txt file is created by the newer versions of DVDDecrypter and it contains information about the audio and video streams of your movie.
All DVDs contain .bup, .ifo & .vob files. The audio languages, the video streams and the subtitles are contained within the .vob files. The ifos are InFormatiOn files, to help the DVD player navigate in the vobs and the bups are ifo BackUPs. When there are bad sectors over the ifos, the DVD will use the bup instead, if it's ok. -
There`s no need to convert the ac3 to wav cause its already dvd compliant and much smaller than wav format.The volume in ac3 is lower due to the fact that there is a greater dynamic range in the audible levels.
Thank you guys for the info about .bup, .ifo and .vob files it was of great help to me.
For johns0, I converted the ac3 audio to wav because I don't know of any program for editing such files, anyway space was no problem.
How to add audio(.mp3) & adjust in video(.mkv) & burn in vbo ?
By ashe09 in forum AudioReplies: 0Last Post: 16th Jul 2011, 04:06 -
DVD Folders - Video TS & Audio TS
By bdr13278 in forum Authoring (DVD)Replies: 20Last Post: 21st Feb 2010, 13:40 -
DVD RIPPING....Problem syncronizing video with audio accurately.......
By R.STEED in forum Newbie / General discussionsReplies: 1Last Post: 29th Apr 2009, 21:14 -
How Do Take The Video & Audio Off Of My Computer & Put It On A TV?
By Ghettorapboy7 in forum Newbie / General discussionsReplies: 4Last Post: 30th May 2007, 11:25
