i posted this in the newbie/general discussion by mistake and apologize for the misplacement so i am posting it here too simply because i am desperate.![]()
Ok, next time edit your other post please or request it to be
deleted via the feedback forum. I have taken care of it this time.
Mod Offline
Hey guys I am new to this forum as well as DVD ripping and I am at my wits end SOOOOOOOOOOO I'm hoping someone, anyone can help me. Lordsmurf has been good enough to answer a few of my questions but I'm stuck at a certain point.
Ok so I want to rip and copy my first dvd. I bought dvd x platinum, a hacked version and guess what it didn't work. So I surfed some more before I found this site. Thanks to Lordsmurf as well as this forum I downloaded: DvD Shrink, DvD decrypter and Img Tools from this site. I also went and downloaded a trial version of Nero 6.
Basically I muddled my way through decrypter, dvd shrink and img tools. I got all the way to the final step "create and burn image" and it was working until it hit 21% at which time it stopped, the screen was on and the time was counting but the bars all stopped. I waited over 20 minutes and nothing happened. I attempted to cancel and nothing so I rebooted. I checked my dvd and it said it was full, the 4.65 GB size of the movie so I'm thinking maybe just maybe it worked. I previewed the movie and it worked, menus and extras, at least the first couple chapters. I went in and selected a chapter at the end and of course it didn't work, which I expected.
I consulted with my guide again and was lost so I checked the directory where I saved files and thought that because I had all the files, .iso_00 file, .iso_01 file, .iso_02 file, .iso_03 file, .iso_04 file and a .lst file that maybe i could just burn these to a dvd like i do other data files using roxio cd & dvd creator - wrong. the files burned but when i tried the dvd it just hung up my system until i removed the disc.
So here I sit completely lost. I've spent almost 2 days on this ruined two DvDs and I'm really depressed. Can anyone please help me?
Some background: I am following the DVD shrink guide at http://www.dvdr-digest.com/articles/23_1.html; I am using Win ME; I have dvd encrypter, dvd shrink, img tools and trial version of nero installed; I have a dir with my decrypted movie also dvd shrunk that is comprised of 2 subfolders entitled "AUDIO_TS" and "VIDEO_TS" which is 4.35 GB; in addition I have a dir which I used to run img tools burn to burn my dvd from my hard disk to a blank dvd+r which has the files above (.iso_00 file, .iso_01 file, .iso_02 file, .iso_03 file, .iso_04 file and a .lst file) a total size of 4.36 GB.
I was reading the dvd shrink guide and it stated the following: The .IMG image file produced will most likely be larger than 4 GB in size. Windows 98/Me have problems with single files of larger than 4 GB, and so, it is essential that you do this step under an operating system capable of handling large files (Windows 2000/XP). You can by-pass this problem by burning the 'disc1' and 'disc2' directories without making an image file, eg. by using the "DVD" recording profile under Nero Burning ROM (instructions are not provided here, but it is very straight foward for anyone who has used Nero prior).
Could this be my problem since I'm using Win ME and if so how do I do this? I tried to look at nero and could not find anything about "DVD recording profile under Nero Burning ROM" so I chose to quit and come here.
Sorry for the length of this post I am just trying to provide as many facts as possible in the hopes someone who has expertise in copying dvd's can help me.
my email is wmb72@adelphia.net and i would appreciate any help.
Results 1 to 26 of 26
please dont cross post:
https://www.videohelp.com/forum/viewtopic.php?t=225475 -
Read the first sentence in his post for crying out loud before you post this crap!Originally Posted by sitlet
Yea like I said I was desperate and didn't see the correct forum. I got excited when I saw two replies, unfortunately neither was what I was hoping to read.
Okay, the first piece of advice would be using DVD RW for testing.
Try this way:
1. Rip the DVD to hard drive using DVD Decrypter in File Mode (press F). Select all files before ripping (Ctrl+A).
2. In DVD Shrink, click Open Files and select the folder with the ripped files. Ensure that Full Disc button is selected. Click Backup to compress the files into a new folder.
3. Open Nero - New compilation (Ctrl+N), change CD to DVD in the drop-down box in the top left corner. Select DVD-Video in the list on the left. Click New. It will create an empty compilation with AUDIO_TS and red VIDEO_TS folders.
4. Drag-and-drop all the files created by DVD Shrink into the red VIDEO_TS folder. Ensure that your burner is selected on the main toolbar. Burn. -
dimmer thanks i'll try this tomorrow i'm wasted now. the only bad thing is i have to repeat the whole process again from ripping on down? yuck, was hoping i could just pick up where i left off at another stage. also, i used a dvd+r/w with the idea of testing my burn the problem is i used the wrong type of burn under roxio easy cd/dvd creator.Originally Posted by Dimmer
think i could burn those .iso files that i listed and that .lst file using nero as you suggested or do i have to reapeat the entire process yet again?
thanks for the help. -
Since you use WinME, you're not going to have much success with ISO files because of the 4Gb file size limit. I suggest you start from scratch and do it properly this time. It should take too long to rip a disc. What's an extra half an hour after all you've been through!Originally Posted by masterblaster
masterblaster,
follow dimmers steps and you should ok, to give a better idea of how to rip using DVD Decrypter follow this simulated guide
http://www.dvdshrink.info/dvd-decrypter.php
to shrink your DVD follow this simulated guide, but as dimmer stated click open files instead of open disc - the rest of the steps are the same.
http://www.dvdshrink.info/fulldisk_basic.php
If your going to burn using nero then follow this simulated guide, its what dimmer is trying to explain to you.
http://www.dvdshrink.info/nero-video.php
hope it helps
kas -
Thanks guys. Ok I wondered if my using Win ME wasn't a problem, ugh. It seems like a lot of these things dislike ME my problem is I hate to spend the $$$ to get XP especially a full from scratch version.
One more dumb question. I'm using the trial version of Nero 6, I'm assuming this will run out and I'll have to pay for the full version yes? -
Not a dumb question. Yes you will have to purchase Nero, but you
might be able to get a cheaper copy on ebay or a 2nd hand earlier
version. -
i believe the trail version of nero expires in a month. i had a demo version a year or two ago, but i dont remember how long it lasted. but i think its a month
Thanks for saying my question wasn't dumb being new to all this I feel lost plus having problems doesn't help so I'm just unsure of myself.
It is a minefield.Thanks for saying my question wasn't dumb being new to all this I feel lost plus having problems doesn't help so I'm just unsure of myself.
Nobody here was born with knowledge, we all
had to learn it. Some forget that. -
Well guys I'm close to destroying something here...a whole day later, I followed everyone's suggestions and yet I cannot get nero to successfully burn to dvd. I tried a dvd+r and two different dvd+r/w and everytime the burn fails.
I thought maybe it was my burner so I tested it by burning some data files under roxio the way I have been doing for months and it worked. This is just insane already, I'm at the end of my rope on this stuff.
I am posting two different error logs that Nero gave me. Maybe someone will understand what they are supposedly reporting. I know one thing, it's not normal for your dvd to open and close four to five times before and during a burn, or is it?
Here is error log 1:
wmb
Windows 98 4.90 (ME)
IA32
WinAspi: File 'Wnaspi32.dll': Ver=1, 0, 0, 0, size=36864 bytes, created 6/8/2000 5:00:00 PM
ahead WinASPI: File 'C:\PROGRAM FILES\AHEAD\NERO\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 12/16/2003 8:18:06 PM
Nero version: 6.3.1.15
Recorder: <DVDRW IDE1008> Version: 0054 - HA 0 TA 0 - 6.3.1.15
Adapter driver: <ESDI_506> HA 0
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <DVDRW IDE1008 >Version: 0054 - HA 0 TA 0 - 6.3.1.15
DVDRW IDE1008 (Target 0, F
: Autoinsert On, DMA On, Disconnect On, SyncDataXfer Off
LITE-ON LTR-24102B (Target 1, G
: Autoinsert On, DMA Off, Disconnect On, SyncDataXfer Off
Excluded drive IDs:
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 511MB (523724kB)
Free physical memory: 0MB (40kB)
Memory in use : 63 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
13.6.2004
UDF/ISO compilation
8:58:14 PM #1 Text 0 File Scsicmd.cpp, Line 1609
SCSI timeout (2), 40000ms, CDB Data[hex]: 95 00 00 00 00 00 00 00 00 00 00 44
8:58:14 PM #2 SCSI -1000 File Cdrdrv.cpp, Line 1188
SCSI Exec, HA 0, TA 0, LUN 0, buffer 0x05B66000
Status: 0x00 (0x02, SCSI_PENDING)
HA-Status 0x00 (0x00, OK)
TA-Status 0x00 (0x00, OK)
Sense Key: 0x00 (KEY_NO_SENSE)
Sense Code: 0x00
Sense Qual: 0x00
CDB Data: 0x95 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x44
Sense Data: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
8:58:14 PM #3 CDR -1175 File Cdrdrv.cpp, Line 1204
Internal trace
Command timeout occured: timeout 40000ms, counter 0
8:58:14 PM #4 SCSI -26 File Cdrdrv.cpp, Line 1231
Sense Code: 0x00
Sense Qual: 0x00
8:59:14 PM #5 Text 0 File Scsicmd.cpp, Line 1609
SCSI timeout (2), 30000ms, CDB Data[hex]: AD 00 00 00 00 00 00 00 08 04 00 00
8:59:14 PM #6 SCSI -1000 File Cdrdrv.cpp, Line 1188
Sense Code: 0x00
Sense Qual: 0x00
CDB Data: 0xAD 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x08 0x04 0x00 0x00
8:59:14 PM #7 CDR -1175 File Cdrdrv.cpp, Line 1204
Internal trace
Command timeout occured: timeout 30000ms, counter 0
8:59:14 PM #8 SCSI -26 File Cdrdrv.cpp, Line 1231
Sense Code: 0x00
Sense Qual: 0x00
8:59:15 PM #9 Phase 112 File dlgbrnst.cpp, Line 1845
DVD-Video files reallocation started
8:59:15 PM #10 Phase 114 File dlgbrnst.cpp, Line 1845
DVD-Video files reallocation completed (no file modified)
8:59:15 PM #11 Text 0 File Isodoc.cpp, Line 6065
Iso document burn settings
Determine maximum speed : TRUE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet :FALSE
Allow pathdepth more than 8 directories : FALSE
Allow more than 255 characters in path : FALSE
Write ISO9660 ;1 file extensions : TRUE
8:59:15 PM #12 Phase 111 File dlgbrnst.cpp, Line 1845
DVD-Video files sorted
8:59:16 PM #13 Text 0 File Reader.cpp, Line 118
Reader running
8:59:16 PM #14 Text 0 File Writer.cpp, Line 124
Writer DVDRW IDE1008 running
9:00:16 PM #15 Text 0 File Scsicmd.cpp, Line 1609
9:00:16 PM #16 SCSI -1000 File Cdrdrv.cpp, Line 1188
Sense Code: 0x00
Sense Qual: 0x00
9:00:16 PM #17 CDR -1175 File Cdrdrv.cpp, Line 1204
Internal trace
9:00:16 PM #18 SCSI -26 File Cdrdrv.cpp, Line 1231
Sense Code: 0x00
Sense Qual: 0x00
9:01:16 PM #19 Text 0 File Scsicmd.cpp, Line 1609
9:01:16 PM #20 SCSI -1000 File Cdrdrv.cpp, Line 1188
Sense Code: 0x00
Sense Qual: 0x00
9:01:16 PM #21 CDR -1175 File Cdrdrv.cpp, Line 1204
Internal trace
9:01:16 PM #22 SCSI -26 File Cdrdrv.cpp, Line 1231
Sense Code: 0x00
Sense Qual: 0x00
9:01:17 PM #23 ISO9660GEN -11 File geniso.cpp, Line 3899
First writeable address = 0 (0x00000000)
9:01:17 PM #24 ISO9660GEN -11 File geniso.cpp, Line 3899
9:01:17 PM #25 Text 0 File Burncd.cpp, Line 3167
Turn on Disc-at-once, using DVD media
9:01:54 PM #26 Text 0 File DlgWaitCD.cpp, Line 245
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 2286192 (508:02.42, 4465MB)
9:01:54 PM #27 Text 0 File DlgWaitCD.cpp, Line 257
Write in overburning mode: NO (enabled: CD)
9:01:54 PM #28 Text 0 File DlgWaitCD.cpp, Line 2137
Recorder: DVDRW IDE1008, Media type: DVD+RW
Disc Manufacturer ID: RICOHJPN, Media Type ID: W11, Product revision number: 1
Disc Application Code: 0, Extended Information Indicators: 1
9:01:54 PM #29 Text 0 File DlgWaitCD.cpp, Line 418
>>> Protocol of DlgWaitCD activities: <<<
Insert empty disc to write to.
(Medium in drive: Unknown. Medium required by compilation: DVD+R/RW, DVD-R/RW.)
9:01:54 PM #30 Text 0 File ThreadedTransferInterface.cpp, Line 813
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original disc pos #0 + 2286192 (2286192) = #2286192/508:2.42
relocatable, disc pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2286192 blocks [DVDRW IDE1008 ]
1: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (0) not provided
original disc pos #0 + 1 (1) = #1/0:0.1
relocatable, disc pos for caching/writing not required/not required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1 blocks [DVDRW IDE1008 ]
9:01:54 PM #31 Text 0 File ThreadedTransferInterface.cpp, Line 983
Prepare recorder [DVDRW IDE1008 ] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 2:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4682121216, ISRC ""
2: TRM_DATA_MODE1, 2048/0x00, FilePos 4682121216 4682121216 4682123264, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
0 | lead-in | 0 | 0x00 | 0x41
0 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
2286192 | 2 | 0 | 0x00 | 0x41
2286192 | 2 | 1 | 0x00 | 0x41
2286193 | lead-out | 1 | 0x00 | 0x41
9:01:54 PM #32 Phase 24 File dlgbrnst.cpp, Line 1845
Caching of files started
9:01:54 PM #33 Text 0 File Burncd.cpp, Line 4177
Cache writing successful.
9:01:54 PM #34 Phase 25 File dlgbrnst.cpp, Line 1845
Caching of files completed
9:01:54 PM #35 Phase 28 File dlgbrnst.cpp, Line 1845
Speed measurement started
9:01:54 PM #36 Text 0 File ThreadedTransferInterface.cpp, Line 2343
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
9:01:54 PM #37 Text 0 File ThreadedTransferInterface.cpp, Line 2343
Verifying disc position of item 1 (relocatable, no disc pos, no patch infos, orig at #0): write at #0
9:16:03 PM #38 Text 0 File ThreadedTransfer.cpp, Line 229
all writers idle, stopping conversion
9:16:06 PM #39 Text 0 File WriterStatus.cpp, Line 115
<DVDRW IDE1008 > start writing Lead-Out at LBA 1 (1h), lenght 0 blocks
9:16:06 PM #40 Text 0 File ThreadedTransfer.cpp, Line 229
9:16:06 PM #41 Text 0 File dlgbrnst.cpp, Line 1703
Set remaining time: 0:00,000 (0ms) -> OK
9:16:06 PM #42 Phase 29 File dlgbrnst.cpp, Line 1796
Speed measurement completed: 3.9x (5,454 KB/s)
9:16:06 PM #43 Text 0 File Burncd.cpp, Line 4242
Can only write at 2x instead of 4x, because speed of source data is too slow
9:16:06 PM #44 Phase 36 File dlgbrnst.cpp, Line 1845
Burn process started at 2x (2,770 KB/s)
9:16:06 PM #45 Text 0 File ThreadedTransferInterface.cpp, Line 2343
9:16:06 PM #46 Text 0 File ThreadedTransferInterface.cpp, Line 2343
9:16:06 PM #47 Text 0 File Cdrdrv.cpp, Line 8120
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+RW (9), Part Version: 2
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: re-writable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26053F h
End Sector Number in Layer 0: 0 h
Data in Burst Cutting Area (BCA) does not exist
Disc Application Code: 0 / 0 h
Extended Information indicators: 1 h
Media type ID: W11
Number of Physical format information bytes in use in ADIP up to byte 63: 57
Media Specific [16..63]:
00 00 01 52 49 43 4F 48 - 4A 50 4E 57 31 31 01 39 ...RICOHJPNW11.9
23 00 8A 86 68 02 26 00 - 8A 86 70 02 28 00 8A 86 #...h.&...p.(...
6A 02 28 22 12 10 E0 00 - F0 00 00 00 00 00 00 00 j.("............
9:18:04 PM #48 SCSI -1033 File Cdrdrv.cpp, Line 1188
Status: 0x04 (0x01, SCSI_ERR)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x02 (KEY_NOT_READY)
Sense Code: 0x04
Sense Qual: 0x01
CDB Data: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x02 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x04 0x01
9:18:04 PM #49 Text 0 File dlgbrnst.cpp, Line 1703
Set remaining time: 28:30,392 (1710392ms) -> OK
9:18:04 PM #50 Text 0 File DVDPlusRW.cpp, Line 607
Start write address at LBA 0
DVD high compatibility mode: Yes
9:18:04 PM #51 CDR -3 File ThreadedTransferInterface.cpp, Line 1613
Recorder function not implemented
DVDRW IDE1008\H0 T0
9:18:04 PM #52 TRANSFER -27 File ThreadedTransferInterface.cpp, Line 1613
Could not perform start of Disc-at-once
9:18:04 PM #53 SCSI -1033 File Cdrdrv.cpp, Line 1188
SCSI Exec, HA 0, TA 0, LUN 0, buffer 0x022EAE20
Sense Code: 0x04
Sense Qual: 0x01
CDB Data: 0x55 0x10 0x00 0x00 0x00 0x00 0x00 0x00 0x3C 0x00 0x00 0x00
ModeSel: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
0x05 0x32 0x01 0xC4 0x08 0x00 0x00 0x00
0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x96
0x00 0x00 0x
9:18:04 PM #54 SCSI -1033 File Cdrdrv.cpp, Line 1188
Sense Code: 0x04
Sense Qual: 0x01
0x05 0x32 0x02 0xC4 0x08 0x00 0x00 0x00
0x00 0x00 0x
9:18:04 PM #55 Text 0 File dlgbrnst.cpp, Line 1703
9:18:04 PM #56 CDR -1033 File WriterStatus.cpp, Line 169
Drive not ready
9:18:04 PM #57 TRANSFER -39 File WriterStatus.cpp, Line 169
Could not perform EndSession
9:18:05 PM #58 Phase 38 File dlgbrnst.cpp, Line 1845
Burn process failed at 2x (2,770 KB/s)
Existing drivers:
File 'IoSubSys\SCSI1HLP.VXD': Ver=4.90.3000, size=19278 bytes, created 6/8/2000 5:00:00 PM
File 'IoSubsys\NEROCD95.VXD': Ver=4.5.0.14, size=39882 bytes, created 3/11/2002 11:55:38 AM
File 'IoSubsys\CDR4VSD.VXD': Ver=6.2.0.129 , size=102128 bytes, created 10/16/2003 8:15:18 PM
File 'IoSubsys\CDRALVSD.VXD': Ver=6.2.0.129 , size=20043 bytes, created 10/16/2003 8:15:18 PM
File 'IoSubsys\ACBHLPR.VXD': Ver=1.03, size=40500 bytes, created 2/13/2003 12:24:02 PM
File 'IoSubsys\CDUDF.VXD': Ver=6.2.0.129 , size=141045 bytes, created 10/16/2003 8:15:16 PM
File 'IoSubsys\CDUDFRW.VXD': Ver=6.2.0.129 , size=179939 bytes, created 10/16/2003 8:15:16 PM
File 'IoSubsys\CDRPWD.VXD': Ver=6.2.0.129 , size=114683 bytes, created 10/16/2003 8:15:16 PM
File 'IoSubsys\CDFS.VXD': Ver=4.90.3000, size=59141 bytes, created 6/8/2000 5:00:00 PM
File 'IoSubsys\ESDI_506.PDR': Ver=4.90.3000, size=25365 bytes, created 6/8/2000 5:00:00 PM
File '..\System32\Drivers\1394bus.sys': Ver=4.90.3000.1, size=44240 bytes, created 6/8/2000 5:00:00 PM
File '..\System32\Drivers\Ohci1394.sys': Ver=4.90.3000.1, size=49488 bytes, created 6/8/2000 5:00:00 PM
File '..\System32\Drivers\Sbp2port.sys': Ver=4.90.3000.1, size=36336 bytes, created 6/8/2000 5:00:00 PM
File 'IoSubsys\Disktsd.vxd': Ver=4.90.3000, size=18663 bytes, created 6/8/2000 5:00:00 PM
Registry Keys:
Error log 2:
wmb
IA32
Excluded drive IDs:
ShowDrvBufStat : 0
BUFE : 0
Free physical memory: 0MB (76kB)
Memory in use : 65 %
Use Inquiry : 1
13.6.2004
UDF/ISO compilation
10:55:12 PM #1 Phase 112 File dlgbrnst.cpp, Line 1845
10:55:12 PM #2 Phase 114 File dlgbrnst.cpp, Line 1845
10:55:12 PM #3 Text 0 File Isodoc.cpp, Line 6065
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Burning mode : DAO
Mode : 1
Joliet :FALSE
10:55:12 PM #4 Phase 111 File dlgbrnst.cpp, Line 1845
10:55:13 PM #5 Text 0 File Reader.cpp, Line 118
Reader running
10:55:13 PM #6 Text 0 File Writer.cpp, Line 124
10:55:13 PM #7 ISO9660GEN -11 File geniso.cpp, Line 3899
10:55:13 PM #8 ISO9660GEN -11 File geniso.cpp, Line 3899
10:55:13 PM #9 Text 0 File Burncd.cpp, Line 3167
10:55:59 PM #10 Text 0 File DlgWaitCD.cpp, Line 245
10:55:59 PM #11 Text 0 File DlgWaitCD.cpp, Line 257
10:55:59 PM #12 Text 0 File DlgWaitCD.cpp, Line 2137
10:55:59 PM #13 Text 0 File DlgWaitCD.cpp, Line 418
10:55:59 PM #14 Text 0 File ThreadedTransferInterface.cpp, Line 813
10:55:59 PM #15 Text 0 File ThreadedTransferInterface.cpp, Line 983
DAO infos:
MCN: ""
Tracks 1 to 2:
DAO layout:
10:55:59 PM #16 Phase 24 File dlgbrnst.cpp, Line 1845
10:55:59 PM #17 Text 0 File Burncd.cpp, Line 4177
10:55:59 PM #18 Phase 25 File dlgbrnst.cpp, Line 1845
10:55:59 PM #19 Phase 28 File dlgbrnst.cpp, Line 1845
10:55:59 PM #20 Text 0 File ThreadedTransferInterface.cpp, Line 2343
10:55:59 PM #21 Text 0 File ThreadedTransferInterface.cpp, Line 2343
11:11:28 PM #22 Text 0 File ThreadedTransfer.cpp, Line 229
11:11:34 PM #23 Text 0 File WriterStatus.cpp, Line 115
11:11:34 PM #24 Text 0 File ThreadedTransfer.cpp, Line 229
11:11:34 PM #25 Text 0 File dlgbrnst.cpp, Line 1703
11:11:34 PM #26 Phase 29 File dlgbrnst.cpp, Line 1796
Speed measurement completed: 3.6x (4,982 KB/s)
11:11:34 PM #27 Text 0 File Burncd.cpp, Line 4242
11:11:34 PM #28 Phase 36 File dlgbrnst.cpp, Line 1845
11:11:35 PM #29 Text 0 File ThreadedTransferInterface.cpp, Line 2343
11:11:35 PM #30 Text 0 File ThreadedTransferInterface.cpp, Line 2343
11:11:35 PM #31 Text 0 File Cdrdrv.cpp, Line 8120
Media type ID: W11
11:12:35 PM #32 Text 0 File Scsicmd.cpp, Line 1609
11:12:35 PM #33 SCSI -1000 File Cdrdrv.cpp, Line 1188
SCSI Exec, HA 0, TA 0, LUN 0, buffer 0x05B48000
Sense Code: 0x00
Sense Qual: 0x00
11:12:35 PM #34 CDR -1175 File Cdrdrv.cpp, Line 1204
Internal trace
11:12:35 PM #35 SCSI -26 File Cdrdrv.cpp, Line 1231
Sense Code: 0x00
Sense Qual: 0x00
11:13:42 PM #36 Text 0 File dlgbrnst.cpp, Line 1703
11:13:42 PM #37 Text 0 File DVDPlusRW.cpp, Line 607
11:13:42 PM #38 CDR -3 File ThreadedTransferInterface.cpp, Line 1613
DVDRW IDE1008\H0 T0
11:13:42 PM #39 TRANSFER -27 File ThreadedTransferInterface.cpp, Line 1613
11:13:42 PM #40 Text 0 File dlgbrnst.cpp, Line 1703
11:13:42 PM #41 Phase 38 File dlgbrnst.cpp, Line 1845
Existing drivers:
Registry Keys: -
It appears that Nero concludes the PC is too slow to write at 4x speed and attempts to write DVD+RW at 2x speed, while the minimum for +RW is 2.4x. You should disable the Determine Maximum Speed option in the Burn window. Check that HDD has DMA enabled. Also, try using a 2.4x DVD+RW if you have one.
Maybe whatever other burning software you have can write a DVD-Video compilation. -
Did you say Roxio ?
Roxio and Nero will not cohabitate. You will be getting all sorts
of weird and wonderful errors. You have to remove both, reboot
and install just one of them. I suggest Nero. -
Originally Posted by offline
Really? That's pretty crappy but it makes sense I just hope it's something that simple. I will uninstall them both then reinstall the trial version of Nero and see what happens. I'm just going to try that another day, I've had enough problems the last couple days with this that I need a break.
Thanks again for the help and I'll be sure to post how I made out from this latest attempt.
Well I removed roxio and nero then reinstalled nero and tried again and no luck. The process got further such as completing the speed test but when it came time to actually do the burn it failed, for the third time.
Here is the latest error log it reported:
wmb72
IA32
Excluded drive IDs:
ShowDrvBufStat : 0
BUFE : 0
Free physical memory: 0MB (44kB)
Memory in use : 60 %
Use Inquiry : 1
16.6.2004
UDF/ISO compilation
1:41:31 PM #1 Phase 112 File dlgbrnst.cpp, Line 1845
1:41:31 PM #2 Phase 114 File dlgbrnst.cpp, Line 1845
1:41:31 PM #3 Text 0 File Isodoc.cpp, Line 6065
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Burning mode : DAO
Mode : 1
Joliet :FALSE
1:41:31 PM #4 Phase 111 File dlgbrnst.cpp, Line 1845
1:41:32 PM #5 Text 0 File Reader.cpp, Line 118
Reader running
1:41:32 PM #6 Text 0 File Writer.cpp, Line 124
1:41:32 PM #7 ISO9660GEN -11 File geniso.cpp, Line 3899
1:41:32 PM #8 ISO9660GEN -11 File geniso.cpp, Line 3899
1:41:32 PM #9 Text 0 File Burncd.cpp, Line 3167
1:41:57 PM #10 Text 0 File DlgWaitCD.cpp, Line 245
1:41:57 PM #11 Text 0 File DlgWaitCD.cpp, Line 257
1:41:57 PM #12 Text 0 File DlgWaitCD.cpp, Line 2137
1:41:57 PM #13 Text 0 File DlgWaitCD.cpp, Line 418
1:41:57 PM #14 Text 0 File ThreadedTransferInterface.cpp, Line 813
1:41:57 PM #15 Text 0 File ThreadedTransferInterface.cpp, Line 983
DAO infos:
MCN: ""
Tracks 1 to 2:
DAO layout:
1:41:57 PM #16 Phase 24 File dlgbrnst.cpp, Line 1845
1:41:58 PM #17 Text 0 File Burncd.cpp, Line 4177
1:41:58 PM #18 Phase 25 File dlgbrnst.cpp, Line 1845
1:41:58 PM #19 Phase 28 File dlgbrnst.cpp, Line 1845
1:41:58 PM #20 Text 0 File ThreadedTransferInterface.cpp, Line 2343
1:41:58 PM #21 Text 0 File ThreadedTransferInterface.cpp, Line 2343
1:56:38 PM #22 Text 0 File ThreadedTransfer.cpp, Line 229
1:56:40 PM #23 Text 0 File WriterStatus.cpp, Line 115
1:56:40 PM #24 Text 0 File ThreadedTransfer.cpp, Line 229
1:56:40 PM #25 Text 0 File dlgbrnst.cpp, Line 1703
1:56:40 PM #26 Phase 29 File dlgbrnst.cpp, Line 1796
Speed measurement completed: 3.8x (5,270 KB/s)
1:56:40 PM #27 Text 0 File Burncd.cpp, Line 4242
1:56:40 PM #28 Phase 36 File dlgbrnst.cpp, Line 1845
1:56:40 PM #29 Text 0 File ThreadedTransferInterface.cpp, Line 2343
1:56:40 PM #30 Text 0 File ThreadedTransferInterface.cpp, Line 2343
1:56:40 PM #31 Text 0 File Cdrdrv.cpp, Line 8120
Media type ID: W11
1:58:35 PM #32 SCSI -1033 File Cdrdrv.cpp, Line 1188
Sense Code: 0x04
Sense Qual: 0x01
1:58:35 PM #33 Text 0 File dlgbrnst.cpp, Line 1703
1:58:35 PM #34 Text 0 File DVDPlusRW.cpp, Line 607
1:58:35 PM #35 CDR -3 File ThreadedTransferInterface.cpp, Line 1613
DVDRW IDE1008\H0 T0
1:58:36 PM #36 TRANSFER -27 File ThreadedTransferInterface.cpp, Line 1613
1:58:36 PM #37 SCSI -1033 File Cdrdrv.cpp, Line 1188
Sense Code: 0x04
Sense Qual: 0x01
0x00 0x00 0x
1:58:36 PM #38 SCSI -1033 File Cdrdrv.cpp, Line 1188
Sense Code: 0x04
Sense Qual: 0x01
0x00 0x00 0x
1:58:36 PM #39 Text 0 File dlgbrnst.cpp, Line 1703
1:58:36 PM #40 CDR -1033 File WriterStatus.cpp, Line 169
Drive not ready
1:58:36 PM #41 TRANSFER -39 File WriterStatus.cpp, Line 169
1:58:36 PM #42 Phase 38 File dlgbrnst.cpp, Line 1845
Existing drivers:
Registry Keys: -
I gave up on Nero and tried copy2dvd and after my first attempt it appears as if it worked. The test will be my standalone dvd players so if they work I'm set, finally.
UPDATE: the above worked on my computer's dvd burner but not my standalone dvd player/recorder. i thought i had finally done it when i saw the studio logo trailer play but then 14 seconds into it nothing else, the player was trying to read but it couldn't so i ejected. reinserted and it just picked up at 14 seconds with nothing. i got that disc out fast hoping not to wreck my standalone and here i sit, stuck again.
i just love technology!
I decided not to keep Win ME when I recently started to burn DVD's.
WinME doesn't have the greatest reputation and you also have the file size problems with FAT32. If you take any classes, fulltime/partime/night, (or know someone who takes classes)
You could get (or ask a friend to get) an academic upgrade for Win Xp.
I got an academic WinXP Pro upgrade disk for $84 from an online site named newegg. The regular price is around $200. Yeah, $80 bucks is a fair amount of money, but I personally have had zero problems with Xp Pro and the capture/ripping/burning process had been pretty smooth (just hampered by my own lack of knowledge) -
Originally Posted by csaag
csaag thanks i'll be looking into XP soon simply because i've had enough problems with other software that didn't like ME I just haven't made the move yet because <1>$$ and <2>because I don't want to have to do a clean install i want to go over ME with XP and that is why I have been looking for a full version rather then an upgrade. I saw on the windows xp site that there is an upgradable xp version that works if you previously had ME so that is something else I'll look into. -
I had the Win Xp Pro 'upgrade' disc and you can either install over ME or do a clean install.
AFAIK the only purporse of the 'upgrade ' disc was to give an incentive for people with a previous Windows disc to upgrade more cheaply.
You do need a disc with a previous version of Windows. Some systems come with 'recovery discs' with Windows already pre-installed. I'm not sure if the Xp Upgrade disc will accept that. If that's your case, thne check with Microsoft first before spending $$$. Microsoft also has an 'upgrade advisor' on their support website that checks your system for compatability -
Well you can close out this thread because I successfully burned and played my first dvd - finally. Thank you to everyone who helped with their suggestions it was appreciated greatly.
I'm not ready to disappear because I won't consider this a true success until I do a few movies but I got one under my belt so that's a start.
I'm also going to check out this forum to try and keep up and learn as many new things as I can. Great forum!
mb
masterblaster,
Congrats!
Let us know what you did in the end to get it working.
Using ME is such a problem in general that the advice is often to
forget it and upgrade.
troubleshooting svcd2dvd
By paulpierce034 in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 15th Oct 2010, 21:37 -
troubleshooting DVD Flick
By judiavi in forum Newbie / General discussionsReplies: 6Last Post: 27th Jun 2010, 21:01 -
Need help troubleshooting video capture
By scorpio47 in forum Capturing and VCRReplies: 6Last Post: 13th Feb 2010, 02:48 -
M2TS troubleshooting
By vassock in forum Authoring (Blu-ray)Replies: 1Last Post: 11th Nov 2009, 01:45 -
troubleshooting - empty file?
By Silky Slim in forum ffmpegX general discussionReplies: 4Last Post: 30th Jan 2008, 09:33
