I know u can just burn iso files into dvd...what i want to know is can u convert the iso files to vcd, svcd, or avi????? Can anyone help????
I can help you, first, do you know how to encode a dvd to avi?
If you already know how to do this, you have 2 options:
Option 1 - Burn the iso to a dvd and then convert the dvd to avi as you already know how.
Option 2 - Mount the ISO to a virtual drive with programs like Alcohol 120% or Daemon and then convert the dvd to avi as you already know how.
*If you don't know how to convert the dvd to avi or svcd then you can use programs like SimpleDivx, DVDX, FairUse, AutoGK... There are a ton of guides for these programs on this site and many others.
Good Luck
Is it possible to merge iso-files
By dazler in forum EditingReplies: 7Last Post: 6th Jan 2012, 04:29 -
How to delete ISO files?
By millyvanilly in forum Newbie / General discussionsReplies: 13Last Post: 26th Jan 2009, 15:00 -
ISO Files
By shapper in forum Newbie / General discussionsReplies: 5Last Post: 16th Jul 2008, 09:53 -
help on .iso files!
By fabpozzi in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2008, 16:24 -
iso files
By king2136 in forum Authoring (DVD)Replies: 2Last Post: 30th Sep 2007, 09:10
